high compression pistons
well, i think my piston rings are starting to wear out, and i was wondering if any companys make high compression pistons for the B6 motor. Thanks in adavance for any info.
ProtegeSTS
Re: high compression pistons
<P>880 bucks from TODA. They overbore to 81mm, and are 11:1 compression. These are about the best you can get.<P>Any other company, JE, SRP, Wiesco....they will all be able to do them. You may need to send a single piston to them for them to take tolerances.<p>[ July 20, 2002: Message edited by: ProtegeSTS ]-93 MR2
#129 E-stock
#129 E-stock
boostedmx
wiseco also makes a set for alot cheaper. they overbore 1mm and have proven very race worthy in miata applications. check them out <A HREF="http://www.flyinmiata.com" TARGET=_blank>www.flyinmiata.com</A>
