New Car!!!!! What to do? Comments Wanted!!
mclaw-mclaren
New car and anxious to do Mods, suggestions!
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
mclaw-mclaren
Re: New Car!!!!! What to do? Comments Wanted!!
I guess you need a pic<P><A HREF="http://www.geocities.com/travissheba/index.html" TARGET=_blank>web page</A>
~~McLaw~~
MX-3 -- BPT
MX-3 -- BPT
here are a few to add to your list<P>clear corner turn signals<BR>Clear Side markers<BR>Front Bumper cover<BR>Side skirts<BR>Rear Mud Flaps<BR>New muffler or Cat-back exhaust system<BR>Custom painting dash trim pieces<BR>Indiglo gauge dials<BR>Guage rings<BR>stainless steel side sills<BR>stainless steel brake lines & Clutch line<BR>PRM jetstream cold air intake<BR>Magnacore 8.5mm Ignition(spark) wires<BR>Turbo engine swap<BR>The list goes on and others will be able to add what I've left off<P>Nice car and good luck with it - you have a good start.<p>[ June 24, 2002: Message edited by: Maddbuck ]
I admit it: I'm mostly ignorant when it comes to engines, so Maddbuck why the change to Magnacore 8.5mm Ignition(spark) wires ?<BR>Will it make any difference on a Stock engine (V6) or is it only if you're doing a engine swarp ?
Everyone seems to use them and like them. They are expensive for wires but they seem to hold up better to the harsh conditions within the engine bay of the V6. I had the misfire problem when I bought my V6 but the old wires were bad so I just got new ones and went for the magnacore since I had used them before on my 4cyl MX-3 which made a good difference.
- The_Great_Tonge
Well save your money and if you got a v6 snatch a
(Kl-ze) or if you got a 4cyln get the
(b6t). Forget EVERYTHING else!
