Help... got car checked out at Mazda.. NEED HELP!
Mx3Mazda
Post by Mx3Mazda »
OK, PLEASE IF U READ THIS.. REPLY.. I NEED UR ADVICE ON WHETHER I SHOULD BUY IT OR NOT<BR>ok well as u know i was lookin at a 92 GS to buy, and i found one.. well i took it to Mazda and this is what they found (ill write everything)<BR>*Needs wiper blades<BR>*Noted V/C Gasket Leaking (Rear Worse, recommended replace both)<BR>*Noted lower ball joints loose<BR>*Noted Left Axle Boot cracked<BR>*Alt Belt Weather cracked<BR>*Left Stab. Link Loose<BR>*Right Rear Strut Leaking<BR>*Both Rear Boots Split<BR>*Front and Rear Brakes 60% wear left<BR>*Front Rotors warped <BR>*Left front tire out of round<BR>*steering wheel off center<BR>OK, so thats wat they gave me, i need clarification as to what the V/C gaskets, the left axle boot, the Alt belt weathered, the left stab link, rear strut Leaking? and rear strut boots are, and also i need to know how much of this work is fairly easy to do?? <BR>PLEASE POST ANY of ur ADVICE..NE WILL HELP!! Thank You VERY much!<BR>kendal
Show_MX
Re: Help... got car checked out at Mazda.. NEED HELP!
Post by Show_MX »
IMO, i would let the car stay at the dealership. That is gonna be very pricey just to get it to be reliable. <P>-Kevin
mazda_stud
Post by mazda_stud »
yah take that car back to weburn were you got it from.
LIFE IS A HIGHWAY I WANT TO DRIVE IT ALL NIGHT LONG!
