hatch light
Posted: April 20th, 2002, 12:33 am
by fairyangel
my hatch light went out a while ago and I have absolutely no idea how to fix it. I'm scared I might break the cover for it. Does anyone know a safe way to fix it without prying the cover too much?
Re: hatch light
Posted: April 20th, 2002, 1:01 pm
by Maddbuck
unscrew the speaker cover, pop it up and you can push it out from behind. The easiest way is to pry it out with a screw driver, the side closed to the back of the car. Also check in the car's manual under the maintenance section it should show you there as well.<BR>
