hatch light
fairyangel
hatch light
Post by fairyangel »
my hatch light went out a while ago and I have absolutely no idea how to fix it. I'm scared I might break the cover for it. Does anyone know a safe way to fix it without prying the cover too much?
~ Vrooom! Vrooom! See my tailights flashing...dissin' ya...dissin' ya! R U Ready? ~
Maddbuck
Re: hatch light
Post by Maddbuck »
unscrew the speaker cover, pop it up and you can push it out from behind. The easiest way is to pry it out with a screw driver, the side closed to the back of the car. Also check in the car's manual under the maintenance section it should show you there as well.<BR> :roll:
