Hey guys,
I bought these 2 12" subs and the custom factory EL Series box from my brother-in-law at the end of summer. He used them (barely) for like 6 months.
I bought these cause they sound mint and would go nicely with my car. However, due to....umm.....'overspending' on my car durring this off-season, I cant really afford a system this year.
So, I am asking for $300CDN OBO. MAKE ME A REASONABLE OFFER! They are in MINT condition. I will deliver too (within reason)!
If you are interested and I am NOT online, email me at events@toprotege.com
Go to http://www.bazooka.com/productAutoRawWoofersEL.asp?id=41 for specs.
Box Specs: 30" wide x 14" high x 13" deep at the bottom/10" deep at the top (it has an angled back so it fits snuggly against your seats). Its very compact and will leave lots of hatch/trunk space.
ELW1214
EL Series 12 inch 4 ohm woofer
MSRP: $129.95 USD
Reinforced poly cone, rubber surround, flat / progressive spider, stepped side vented basket, bumped back plate with rear vented pole piece and nickel plated spring loaded barrel terminals. Liquid cooling optional with addition of CHIL-PLUG.
Power Handling 350 w
Power Handling with Liquid Cooling 450 w
Impedance 4 ohms
Sensitivity 92 dB
Frequency Response 20Hz-1000Hz
Recommended Power 50w - 275w (RMS)
Voice Coil Size 2"
Magnet Weight 40
Sealed Enclosure .93 cu ft
Ported Enclosure 2.0 cu ft
Port Length 15.71 in
Port Diameter 4 in
Mounting Depth 5 5/8 in
Cutout Size 11 1/8 in
Fs 30
Qts 0.36
Qms 4.98
Qes 0.39
Vas 3.10
Xmax 1.12 in. (total xmax)
Re 3.6
Le 1.4
<img src="http://images.cardomain.com/member_imag ... 4_full.jpg" alt=" - " />
<img src="http://images.cardomain.com/member_imag ... 5_full.jpg" alt=" - " />
<img src="http://images.cardomain.com/member_imag ... 6_full.jpg" alt=" - " />
<img src="http://images.cardomain.com/member_imag ... 7_full.jpg" alt=" - " />
<small>[ February 22, 2004, 04:49 PM: Message edited by: KDawgONE ]</small>
FS: 2 12" EL Bazooka subs in factory box *PICS*
KDawgONE
Kris
Toronto Protege Club Events Co-Ordinator
1997 Protege 1.8 LX
JDM front bumper, JDM heads, JDM corners, JDM hood scoop, JDM tails, etc, etc...
http://www.sounddomain.com/id/kdawgone
1997 Protege 1.8 LX
