92 mx3 sohc engine and transmission. 91,000 miles. New water pump, alternator, distributor, clutch, and timing belts within the last 18,000 miles. Will come with the header and oxygen sensor. The only thing that I am not including is the throttle body because that is already sold. Runs great does not burn any oil. $380.obo
ecu and wiring harness $50.00
Email me at gaugemounts@aol.com if interested
b6 engine and transmission ecu and wiring harness
agfcomp@aol.com
Re: b6 engine and transmission ecu and wiring harness
i am interested in replacing my 93 sohc. what would shipping and handling to zip code 46628. What is your reason for selling the engine, and would the engine swap right in, or would there be any differences because of years? thanks alot
