Umm... yeah.. Pretty sure he replaced that. And he swapped the entire TB off of another car. The Base idle needs to be reset/calibrated. The IAC only effects the car during warm up and under electrical load. Simple way to test it is just unplug it and drive around. I to was told that it was my IAC by several. It was not.93MAZMX3KLZE wrote:Hey guys !! Adjusting your idle and TPS doesn't fix a broken IAC valve.
kulluminati777 - 1993 マツダスピード MX-3 You will be missed
- Josh
Re: kulluminati777's Two week challenge......
- mx3_ryder
Pretty sure he replaced and said it was not surging anymore. The high idle was because he didn't have the throttle linkage adjusted correctly.
- Josh
I skimmed over that post93MAZMX3KLZE wrote:Pretty sure he replaced and said it was not surging anymore. The high idle was because he didn't have the throttle linkage adjusted correctly.
Hopefully it is fixed for now. Either way it is way better than paying a shop a couple hundred to 1000 to potentially fix the issue.
- mx3_ryder
Yeah, hopefully it fixes his problems. I never like paying mechanics rates these days and always diagnosis and fix problems myself. Getting pretty good with the multimeter.
- MrMazda92
Unplugging the IAC is the winning move, since they clog up and or fail eventually.
If you live in a cold climate, set your idle to 800-900, and let the car warm up for 3-5 minutes on sub freezing mornings. That's the solution to never-ending IAC failures!
- kulluminati777
Re: kulluminati777's Enviromentally friendly KLean ZE
After a few days of huffing it to and from school the car seems to act normal. No surging or anything. I do have a weird tap from the engine and its not HLA´s I know that sound all too well. Ill look into the noise source after we get another car.
I also got the car to the SMOG station. After the tech kept crying about the timing i went out to the parking lot and set it to 10btdc but when he checked it was 13...oh well
it can be within 3 + or -
before i passed it was at 18
so that means it wasnt set correctly after my head gaskets were done although i thought it was......
I had done the following
1. Bought a new cat and took the KLZE in to smog as is. FAILED due to timing at 18btdc and high NoX. It was double the legal limit
but of course i dont have the EGR switched on.
2. Denatured alcohol in the gas tank....being a cheapskate that i am I went to home depot and poured in around 4 liters to a half a tank.....PASSED
I still had the option of a K8 manifold + K8 ECU so i can run the EGR on the KLZE that was rigged up to it but i didnt want to buy a K8 manifold and disconnect and reconnect all these vacuum lines.......
Now i finally have plates
- King58
Congrats
______________________________________________________________________________
94' RS Sold
94' GS Sold
96' GS PROJECT XD
- kulluminati777
thanks, its about time. I been on temp tags and shipping papers for 3 months now......I was pulled over every 10 minutes------King58 wrote:Congrats
i was looking into some custom plate options but all the ones i wanted were taken or i had to use numbers and letters.
I wanted
"MZD SPD" or "MZDASPD" = mazdaspeed
"A Spec" i needed numbers so I tried "A SP3C" but it looked dumb and im sure people would think it means "A Spick"
So I settled on "MZDA MX3" bet ya cant guess what it means
crazycanadian
Congrats bud... The new cat would have helped... most cheepy aftermarket cats will fail on NOx but be ok for everything else...
The idle issues sorted out as well??
For the tick I wouldn't worry to much about it.. its pretty common the KLs... only thing I would do is pull valve covers and plasti gauge the cam clearances... If they are low you can sand down the cam caps and bring the clearances back up tighter... this will help keep bring oil pressure back up and help keep the lifter pumped up preventing the ticking sound..
- kulluminati777
ah ok ill look into doing that and no it wasnt officially sorted out. I got another TB from the wreckers and put it on and all was ok. The idle was high but i just fiddled with the linkage until i got the idle where i wanted it.crazycanadian wrote:Congrats bud... The new cat would have helped... most cheepy aftermarket cats will fail on NOx but be ok for everything else...
- Surgeonasst222
Congratz on passing... You actually made me think for the 1st time in my life I will get a custom plate lol
With the lack of mx's in Michigan I should be able to pick what I want
Mazda3 2012 - my NEW DD
Mazda MX-3 RS 1992 - my project
Ford Focus SE 2010 - sold
Ford Focus SE 2003 - sold
Mazda MX-3 RS 1994 - sold
- kulluminati777
Re: kulluminati777's Big Brake Bananza
I came home from school to a very lovely surprise! My ceika BBK! I had them send me a gold color caliper and rotor so it matches my underhood theme
RobMinhas
Finally, no more Brembo covers!
- MrMazda92
They look nice!
Bolt those puppies up and take some pictures now!
Really interested in how these work for you... how did you order these brakes, how much?
Thanks!
Tim
Thanks!
Tim
