You all think the SOHC is crap...I bet you the rods are the exact same small b6 rods used everywhere else. Racing Mazda and then myself have proven those rods can take over 400WHP for a little while (mine took it for 10,000 miles). The only major set back then would be the cyldiner head design. Port size, valve size, and quench area. The other obviouse set back is the OEM cam duration and lift. Web Cams, or someone of the likes could probably make a custom spec cam for pretty cheap. One possible advantage to the SOHC is that there is less rotating mass (ie less parasitic drag) from the single cam vs. the twin cam. I'm seriously wondering if the SOHC head would out flow the GTX DOHC head. It may use the same valves the MX-3 DOHC engine uses which I belive are larger than the GTX's.
With a Garrett GT3071R series turbo or an Innovative Street Heat 57 with a .63ish a/r exhaust housing & Tial 44mm external gate would be NASTY on a stock SOHC @ 26psi with a standalone & 1000cc injectors (of coarse you need a good intercooler). 300WHP
![Laugh :laugh:](./images/smilies/laugh.gif)
Mini...you need to build another monster
![Welder :welder:](./images/smilies/welder.gif)
