guys guys calm down.. That was just while I was doing some preliminary tuning right after I hooked up the system.. It was at like 10 -12 under throttle, so much so that it would just read "RICH" in the software. My goals are for commuting at this point
it is fine. I am running a pretty constant 12-14 right now, with minor fluctuations which is just my O2 sensor, and a 15-16 at idle. When I first hooked everything up it was running crazy lean at idle about 16-18 then super rich under load. It auto calibrated an up to 5% variable of richness (as most use this system for boost) and I leaned that out so I am running a 2% variable now. most guys I have talked to say they have the best results with this system between a 1% and 3% variable. The car is running incredibly so I am not too worried about anything, though I may benefit from running colder plugs again. I am no longer seeing a plume of black smoke when I get on it, which is nice. Though I have noticed next to no change in my MPG yet, though it has been raining and that tends to lose me a few. I have not yet taken out my VAF, I should be doing that any day, or as soon as I go buy an IAT sensor.
Jforce wrote:
But anyway, eventhough i'm supposed to run leaner with this new chip, I feel i'm still running rich.
I won't pass emmisions actually, 20 mpg I think on highway, quite black sparks, sooted exhaust.
2 years ago id did pass emision, with the KL31 ECU. Wonder what's different.
So that why i bought the wideband.
only 20 MPG! that is crazy I average 25 to 28. I have only gotten as low as 24 and that was a full take of hard driving. I run a pretty constant 26MPG with my commuting. city and highway about 80 or so miles a day. Do you have your EGR hooked up or blocked off? Could be a bad or tired O2 sensor also.
