(facepalm) You cannot put a K8 head on a KL block... different bore.
Every K had a KL dipstick. Completely normal. Other random parts in your car will be stamped KL01, and some random parts in a DE are stamped K8...
What engine do i have
- Ryan
Re: What engine do i have
- john1983
ok that makes alot more sense
92 MX-3 6cyl dohc 24 valve K8 cold air filter custom exhaust drift body kit carbon fiber hood 17" focal rims Kenwood KDC-MP635 headunit Pioneer 6.5" componet door speakers and 4" rear speakers 500 watt boss amp powering 12" sony explod
My Work Logviewtopic.php?f=46&t=76603
Actually the dipsticks from my K8 and my KLZE were different. The KL dipstick actually sat a little further down into the oil pan, I could look at the number on the dipstick thats in it now, but the other is tossed.
93 mx-3 GS (KLZE w/kl01 cams, XTD stage 3 clutch, Outlaw intake/throttle body spacers, throttle body coolant delete, headers, full 2.5" exhaust w/resonator and 40 series flowmaster, filled engine mounts)
99 silverado
99 silverado
- solo_ryder
Believe him or not this is true IIRC. I compared my busted KLZE one to my good k8 one and the k8 one was longer, but the full line was in the same place if you lined the top part up with each other, so in the end it was still accurate.Pritchett wrote:Actually the dipsticks from my K8 and my KLZE were different. The KL dipstick actually sat a little further down into the oil pan, I could look at the number on the dipstick thats in it now, but the other is tossed.
- Hoodzy
I think the easiest way to tell if it was a ZE or k8 was go to 0-60 as fast as you can.. if it's above 8 seconds then its a k8 hahaa
1995 Creek Mica Blue GS
