Page 3 of 4
Re: STS Rear Turbo
Posted: March 5th, 2011, 2:54 pm
by RS_OBD'oh_2
the long tube idea will not cool as much as some people may think. There is not enough surface area or time spent in the tract to allow for proper cooling. This is why intercoolers have a massive surface area and allow air to pass through it. Pressurised air following a path close to a hot exhaust would negate any slight cooling that would take place.
More often on these setups the turbo is mounted in place of the muffler.. the intake is simply plumbed to a rear wheel well. Simple.
Re: STS Rear Turbo
Posted: March 5th, 2011, 3:02 pm
by john1983
imo having your intake in your wheel well seems like a bad location wouldnt this cause problems in inclamate weather
Re: STS Rear Turbo
Posted: March 5th, 2011, 3:13 pm
by RS_OBD'oh_2
it's not that the filter is in the wheel well.. that's where it get the air intake
Re: STS Rear Turbo
Posted: April 24th, 2012, 5:20 pm
by Smashmig
Was reading through this topic, very intrested in the posibilties. Wondering if anyone ev ery thought of doing away with the spare tire hole in the trunk. Leveling that off would get rid of the clearance issue under the car and free up plenty of room. Just spitting ideas out.
Re: STS Rear Turbo
Posted: April 24th, 2012, 6:13 pm
by Josh
If you can fit that big @$$ OE muffler under the rear you can fit a turbo
Re: STS Rear Turbo
Posted: April 24th, 2012, 8:10 pm
by fowljesse
I had the same idea as Nd4SpdSe. You could also vent air around the intake tube for cooling.
Re: STS Rear Turbo
Posted: April 25th, 2012, 12:00 pm
by Josh
See my thought is most of these kits only run like 5 psi so with that long of a charge pipe why do you even need an intercooler? you just loose more boost. If I were doing it to get just a little extra our of my ride I would probably not use a IC and if I did I would use a side mount.
Re: STS Rear Turbo
Posted: March 14th, 2014, 9:12 pm
by posey92
HEY THIS WAS ME!!! LOL
Re: STS Rear Turbo
Posted: May 1st, 2014, 10:41 pm
by posey92
Just wanted to let u all know I will be reviving this topic soon. I have to decided to rebuild a K8 strengthen internals and such may even go as far as to twin charge using the Eaton as well. Ill have help on the drawn out project from a friend who successfully took a 1.5 4 cyl. Turbo supercharged using same Eaton m90 nitrous and alch/meth. More updates cming in a few months as I think I located a very low milage k8 as my base...
Re: STS Rear Turbo
Posted: May 2nd, 2014, 12:01 pm
by RogueWolf
I've got something to top the STS Rear Turbo... for someone who doesn't mind the loud noise of a Sue-pa-cha-ga...
I'm an engineer by trade, and I do a LOT of mobile hydraulics.
So I got to thinking... If instead of having a supercharger mounted inconveniently in the engine bay, I could relocate it somewhere more useful, where I have considerably more space, access to fresh air, and I don't have to worry about going over a speed bump and losing my turbocharger.
Recently I replaced the rear passenger fender, and noticed the large amount of room behind the fender... easily enough to house a high speed Hydraulic Gearator Motor (Parker MGG20025), and a Nice Vortech V5 supercharger.
A couple hydraulic lines a nice little pump in replacement of the a/c unit, and a bit of tubing... and there you go, a remote Supercharger unit.
But it would be noisy.
Re: STS Rear Turbo
Posted: May 2nd, 2014, 12:28 pm
by Nd4SpdSe
There's many, many flaws with that setup, but I'll give you the easy one...
0.58 cu in MGG20025-BA1B3
•3500 RPM max as pump
•5000 RPM max as motor
V-5 F Supercharger
•Max Speed: 52000 RPM
Re: STS Rear Turbo
Posted: May 2nd, 2014, 12:43 pm
by RogueWolf
There would still need gearing between the motor and the supercharger. And you would use a larger volume pump, with a pressure release to prevent the motor from overrunning.
Re: STS Rear Turbo
Posted: May 2nd, 2014, 1:28 pm
by RogueWolf
So we get a 10 - 1 ratio between the motor and the supercharger.
The motor has a torque rating of ~15 ft-lbs @ all RPMS. (Assuming constant/consistant pressure ~1500psi safely.)
Assuming that with a bypass flow control circuit we can keep the motor spinning at a constant operating rpm of 5000.
That makes it yield, 1.5 ft-lbs of torque to the supercharger @ 50,000rpm.
That motor would output 11hp to the supercharger... which is more than enough for a centrifugal.
Now the pump would require a higher flow rate, something around 1.5-1.8 cu in per rotation.
It too would be geared down from the engine, maybe around 2:1. So at 7000 engine RPM it's only at 3500 RPM.
Throughput would mean that the motor would rotate ~3 times for every rotation of the pump... so you get a 1:15 ratio engine speed to the supercharger... at 1000rpm the supercharger spins at 15000rpm.
Above 3300RPM, the flow control bypass would redirect some of the volume flow back through a hydraulic cooling rad and back to the pump, limiting the max RPM of the motor to 5000RPM, and the supercharger max RPM at 50,000.
Is this easier than a STS Turbo? GOD NO... not if you're unfamiliar with hydraulics. But you only have to run two hydraulic hoses (expensive and custom cut), and the air return.
You would also have to custom make a bracket with the gearing for the supercharger and hydraulic motor to mount to, and buy an off the shelf flow controler.
Re: STS Rear Turbo
Posted: May 2nd, 2014, 1:33 pm
by RogueWolf
On top of all that there is a pumping loss resulting from the bypass (pump -> valve -> cooling unit -> pump) which is lost energy.
If the variable displacement pumps weren't so enormously big it would be a perfect solution, you could dial in the supercharger RPM based on engine loading and RPM.
But hey, this was just a thought experiment. Rebuttals are always welcome.
Re: STS Rear Turbo
Posted: June 15th, 2014, 4:38 pm
by posey92
Well bak to the rear mount turbo...traded off my m90 for a complete honda turbo kit...and I will be mounting the turbo where a muffler would go...I havnt had a muffler on my car since I got it...plenty of room. And I will have the intake for the turbo be where the spare tire is in the cabin...sealed off from thr elements..also the charge piping will runthru the car elemenating the need to place it next to the exhaust...all I need is the oil pump ...
