Page 3 of 3
Posted: September 20th, 2007, 10:26 pm
by mazdamx3sohc
limez...no need to be an a-- to me. im trying to get this under control, so please dont get this thing closed on me. go away if you dont wanna help with advice (purpose of this website)
Posted: September 20th, 2007, 11:43 pm
by Limegreen mx-3
aT least ur trying
better than some of these guys here
Posted: September 21st, 2007, 3:35 am
by shameem
V6 alternator swap was one of the easiest swaps i did -
The RS alternator attaches this way-
The GS alt goes in this way-
Both pics are GS alts - but you get the idea..... The GS alt has a slight bump where the bolt goes in and so you would need a longer bolt. I just took the alt to ace hardware and found a bolt that was the right pitch and right length - it has to go through the first hole and thread onto the second hole.
Also when you are tightening the belt you have to loosen up both bolts (top and bottom) - otherwise you are just straining the bracket and not tightening the belt - its kinda common sense .....
Also, its hard to put a new belt in compared to taking the old belt out (the old belt would be stretched out) - but in 2 or 3 days the new belt gets worked in and stretched up and it will squeal again - you will have to retighten it.
Posted: September 21st, 2007, 1:10 pm
by mazdamx3sohc
i used my old belt since its still in perfect shape.
Posted: November 23rd, 2007, 3:06 pm
by bawolvesfan
so can the alt from a klde probe engine be used the same as the gs alt?
Posted: November 23rd, 2007, 5:13 pm
by mazdamx3sohc
probably.
Posted: November 23rd, 2007, 6:24 pm
by Limegreen mx-3
bawolvesfan wrote:so can the alt from a klde probe engine be used the same as the gs alt?
that will work too im using one from a V6 MX-6 KLDE, mx-6 probe same engine.
Posted: November 23rd, 2007, 7:47 pm
by mazdamx3sohc
IMO honestly i didnt feel a difference using my v6 alternator, i still have the same power hesitation when loads are applied. not as often now, but still just as strong of a surge.
