V6 MX3 Solid Urethane Motor Mounts
nolanspawn
Re: V6 MX3 Solid Urethane Motor Mounts
Post by nolanspawn »
Originally posted by babyblueMX3:
is it a hard job to do when the engine is in the car..i mean do you have to take the engine out to install em..I'd be in if it not to much trouble to install
God no you dont have to pull the motor...granted that would be the EASIEST time to do it...you can do it with the motor and transmission still in the car. As soon as I have a set of I4 and V6 mounts in my hands fabrication will begin...until then I cant do much other then check for interest. We are waiting on some mounts from a Mx-3 owner.
<small>[ February 08, 2004, 09:54 PM: Message edited by: nolanspawn ]</small>
1994 Ford Probe 2.0L
AWR R&D
babyblueMX3
Post by babyblueMX3 »
well then you can add my name to the list
RIP 400whp ZE-T MX-3
andy
Post by andy »
I will second that, top left is the rear, bottm left is the front. and yes the fronts bushing is centered, that picture is just an illusion.
If you go to that site, you will also see the engine mount member bushings. anyone replacing the two motor mounts should replace these also.
There is a very good chance that they are garbage by the time you get them out. I will be ordering these also if you don't include these in a kit.
Thanks
Andy P. 93 GS
bubba_03
Post by bubba_03 »
Put my name on the list for sure but how long do you estimate it will take for the developement of these bad boys? Thanks.
papa roached
Post by papa roached »
add me to the list
BATTOSAI
Post by BATTOSAI »
I think that the turbocharged Kl engine I´m working with would need them! Count on me too!!!!
European Mx3 GsRT
killerpickle
Post by killerpickle »
Could someone enlighten me on how you could install these with the engine still in the car? Im a little skeptical.
Tom Alexander
lakersfan1
Post by lakersfan1 »
Put a jack under the car to keep the engine mobilized? I hope that's what 'cha do, because that's how I was planning to do my 626's when the weather gets better.
MrMX3
Post by MrMX3 »
use a block of wood on the jack so you don't do damage to your oilpan, then support the motor with the jack and change them. Safest way aside from suspending the motor with chains and a cherry picker.
Mike
1993 MX-3 GS
2.5l KL-ZE
My Cardomain Page
nolanspawn
Do you guys not 2 motor mounts and 2 transmission mounts? The ones I am selling are technically "transmission mounts: (front and rear). The other two are motor mounts which actually suspension the motor inside the engine bay. If you leave those two in you will be fine.
AWR R&D
andy
Post by andy »
yes, You are correct. The 1.8L v6 has 4 mounts total. leave the two upper mounts in while replacing the two lower mounts. It helps to have a floor jack under the motor but more for helping you to get the old/new motor mounts out/in.
Andy P. 93 GS
GuidoBiRiChiNo
Post by GuidoBiRiChiNo »
I am in!
-italian lonely MX'er-
bubba_03
Post by bubba_03 »
So whats the word when can we expect these things? Can you at least give a rough estimate? :shrug:
13flat
Post by 13flat »
yeah...any idea when these bad boy's will be ready???
Goal: 1/4 mile time of 13.099 or better, N/A. ...still in the works
http://hits4pay.com/members/index.cgi?ittfund
nolanspawn
Sorry I havent updated anyone. **** has been crazy and its been hard to get on the ball with a few projects.
First person to send me a set of V6 MTX Tranny mounts will get a set of solid mounts (wholesale cost) once they are made. Thats the only offer I can extend becuase I dont produce them myself I just work with a company on the designs and they make them.
<small>[ April 06, 2004, 09:51 PM: Message edited by: nolanspawn ]</small>
AWR R&D
