so what is you car's name?
powerman_5000
Re: so what is you car's name?
I call mine the "battle swing" because of the way I sometime take turns and because I also want to rally race as well.
Shoalinfist
When I'm not calling it "a piece of s---" when I hurt myself working on it, I call it the "Bwonens". My friends gave it that name cause of the sound you here when you ride down the rode. You know the sound of all the little imports and stuff w/ the mufflers, Bwe-e-e-e-en...Bwe-e-e-e-e-en...Bwo-o-o-o-on
- Wildman640
I just bought my 93 mx-3. have not given it a name yet, just call it my baby
bubbaflaat
- mitmaks
i think its silly to name a car
but i still like my car
- papa roached
Kryptonite, small, green and it takes down superstang...i mean man
- hotsiit
Yay for old post resurrections
My mx-3 is also sometimes refered to as "the MX" but its name has been "hotness"
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
1983 Mazda RX-7 GSL
1987 Jeep Comanche
- papa roached
i also more commonly call it the 3, the Maz, the Mazda, the good car, the green car, the pocket rocket, the rocket sled, the death trap, the money pit
Honnestly, i have a hard time giving a name to an non-living object
My car's name is Priscilla, given by my dad (Mx-3 "Precidia", "Priscilla", get it?). I havent heard it for quite a while however, unless my parents joke around to familly/friend and call it my "girl friend", if i overhear them i'll jump in an say "You mean Priscilla, right?"
Our 626 when we got it a few years back, way before i got my Mx-3, my dad nick named it Bruce, after Bruce Lee, case they were both from Japan, it's my dad's first import. (he, and I until recently, mistakely though that Bruce Lee was from Japan, but he's actually Chinese. Personally, It never cross my mind to double check that. And you know what, i don't think I told my dad yet either)
We used to always call the 626 "The Mazda", and i still do once in a while, it became habbit until i got my Mx-3. I try to make sure i refer to each one by their proper name, but "The Mazda" still slips, quite often with my familly still.
- azn_kai
most of my friends call it precidia so i call it miss precidia
k.a.melecio
1992 GS Automatic (R.I.P.)
1993 GS Manual
<img src="http://memimage.cardomain.net/member_im ... 9363_1.jpg">
Victoria Park Avenue
1993 GS Manual
Funny Enough, I also named my mx-3 Priscilla. More Recently it has been changed to Preshittya though...
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
Many names my car has been called, though I'm sure you are all familiar with the names assigned upon busted knuckles, tight spots, and things that are hard to reach. On the positive note it has been called 'the MX', 'the Mazda', 'his car', and my fav: 'Whatever color that is-'
She's my car, sometimes a b----, sometimes a sweetheart, always with an attitude!
I just bought a black 93 gs, it's 'blacky', simply cause it's not 'the mx'.
'my mazda' comes to mind though...
93 GS, ATX to MTX swap, chrome 16x7, upper strut bars, SRD LCA bushings.
Upcoming improvements: Tokico/Eibach struts/springs, energy suspension LCA bushings
94 RS MTX, Engine swap completed, ALIVE Again!
95 RS ATX, parts car/project X
