klze turbo kit group buy
Sean Mandell
Re: klze turbo kit group buy
Post by Sean Mandell »
What a surprise!!!pleaz delete this thread as it is misleading and full of uselessness..... :rant2:
rebel2k4
Post by rebel2k4 »
Anyone see my V6 turbo kit? If there is significant interest I'd consider making some pipes.
However it will probably only be exhaust pipes, not intercooler pipes and I wouldnt make people do a group buy.
<small>[ September 16, 2004, 02:21 AM: Message edited by: rebel2k4 ]</small>
98 Ford Ranger 3.0L
papa roached
Post by papa roached »
i might be in for some turbo pipes down the road a bit, im interested
BATTOSAI
Post by BATTOSAI »
Rebel!! Congrats for your 9 psi boosting! I'm keeping an eye on you!!
European Mx3 GsRT
BATTOSAI
Post by BATTOSAI »
Building the piping isn't really that hard! I used the standard Y pipe, cut it below the Y, passed it around the oil pan bolted the turbo and then back to the exhaust. I enlarged 5cm each arm of the Y pipe, and before cutting them I bolted them to a piece of metal in order to respect the flanges angle! I enlarged them to make the downpipe fit between the oil pan and the Y pipe. You just have to relocate the oil filter! I wish I had here mandrel bents of the degree number I needed, I had to search piping on junkyards and cut the curves by hand!! Also there are on Ebay thousands of turbo flanges to weld on your piping to fit the turbo. That's the cheapest way to go!!!!
European Mx3 GsRT
MX3ze@7psi
Post by MX3ze@7psi »
Thats what I'm talking about! Home made turbo kits are always the easiest and cheapest way to go turbo. I did mine all home made and ghetto too and it ran perfect. :2thumbsup:
MX3 KL-DE, probe/mx6 ebay turbo pipes, T3/T4 50 trim @ 8psi, millenia injectors, SAFC2, intercooled,Greddy RS BOV, turbonetic 38mm external wastegate. Wisco 9.5 forged piston, millenia S rods, and high performance rings coiming in soon. Shooting for 400whp this summer.
rebel2k4
Post by rebel2k4 »
Yup for all you guys that want turbo kits, you should really consider doing it yourself. For the money youd spend on a set of pipes, you could buy yourself a nice Hobart Handler 435 with argon gas and materials, and build your own setup.
With a gas MIG it wouldnt take long before you're laying some nice beads.
No saying it has to be ghetto either. Custom work is very respected in my books.
BTW Battosai check my sig for my time at the track last night :) 6-7 psi of boost...
98 Ford Ranger 3.0L
MX3ze@7psi
ryanlindenberg
Post by ryanlindenberg »
Originally posted by Jon_Carnie:
Originally posted by korban:
yes a pyrometer mesures tempreture.. thus jam it in the downpipe so you can get a good exhaust read out to see how rich or lean your runing duh..
? so like i said, exhaust gas temperature :eek:
..duhhhhhhhh, haha
the EGT is different if you are running rich/lean...hence you can use EGT to tune your engine.
CARDOMAIN WITH UPDATED PICS
bubbaflaat
Post by bubbaflaat »
Wow, this is a huge thread that is ridiculously helpfully unhelpful! By the time this guy has these pipes ready Ryan will have a running BP-T!
J/K Ryan! Who wants a Mustache ride?! :freak:
THIS USER HAS BEEN BANNED, DO NOT DEAL WITH HIM. - MX-3.com Admin
bubbaflaat
I'll start making turbo pipes the way this is going!! They will be ready in about four decades!!
ryanlindenberg
jack-*** !!!! hahaha, j/k, i probably will have my bpt working before this gets done....
Selecta
Post by Selecta »
Well I guess this is not going anywhere?
Friends are just enemies who lack the testicular fortitude to kill you.
I'm a 2min man in a 1min universe
94 GS - KLZE, Spec2 Clutch, Fidanza 9lbs FW, 2 1/4 full magnaflow exhaust. 145WHP / 147WTQ
babyblueMX3
Post by babyblueMX3 »
well it hasn't for months :shrug:
RIP 400whp ZE-T MX-3
Selecta
Post by Selecta »
True true..I was really rooting for it though figured if we gave time it would get done..but alas it has been for not.
Return to “Forced Induction”
