What oil are you using???
Re: What oil are you using???
Ya, well just remember the last time you Argentinians got upidy,,,you got your a--*s handed to you in the Falklands. Nuff said.
- MrMazda92
When did all of this happen? I must have missed it whilst sipping wine under my clay tile roof.
Just changed my oil. Used Mobil 1 Synthetic. Pretty expensive stuff but autozone has a 10$ off coupon(if you buy 5 qts, which we need to w/ 4.2qts capacity) which is essentially 1 qt free. Everything running good so far, but I'd be lying if I noticed any difference from the gtx half syn stuff I was running before. And I got a bosch filter.
93 Blaze Red GS
- Inodoro Pereyra
You're not gonna notice a difference. Your engine will.
But you would've noticed a difference if you had used ProLong.
Diogenes of Sinope.
Diogenes of Sinope.
- Surgeonasst222
Ok found my 1992 mx-3 manual
5w-30 for cold months and 10w-30 for the hot months... They also only call for 7.5k oil changes... That was all the way back in 92 with conventional oil recommend not a syn.
I think I am going to go to Menards and grab some Quaker state 10w-30 syn mixture it is a gen III oil, I hear good things about the oil for the price(I can basically get 7 quarts of that stuff for like $20, thats 2 oil changes for my SOHC). Also going to go with a Quaker state oil filter, they are purolator made and great filters for a car I am not going to be driving the snot out of.
A lot of castol fans here... Is that cuz mazda endorses castol for there cars or just a fluke.
Thanks for the feedback on what you guys are using in these great engines, helped me make my choice on what I was going to use!
Mazda3 2012 - my NEW DD
Mazda MX-3 RS 1992 - my project
Ford Focus SE 2010 - sold
Ford Focus SE 2003 - sold
Mazda MX-3 RS 1994 - sold
I'm pretty cautious about using oil additives. You would think if they were as good as they claim to be, manufacturers would recommend them or they would be more widespread.Inodoro Pereyra wrote:You're not gonna notice a difference. Your engine will.
93 Blaze Red GS
- Inodoro Pereyra
I've used this one for years, and I've opened a B8 after using it on it for almost 100K miles (bought the car with 88K, and junked it with 175K) and all the engine's clearances were within factory specs, and the honing marks were still perfect. That to me says good stuff.benyandthejets wrote: I'm pretty cautious about using oil additives. You would think if they were as good as they claim to be, manufacturers would recommend them or they would be more widespread.
Besides that, they guarantee your engine in writing for LIFE. How many manufacturers do that?
Diogenes of Sinope.
Diogenes of Sinope.
Only problem I know of is foaming caused by some additives,,Lucas for one and foam means air and that's not good. Anyway here's the advertising science behind additives. http://www.youtube.com/watch?v=mLyUL3pkngQInodoro Pereyra wrote:I've used this one for years, and I've opened a B8 after using it on it for almost 100K miles (bought the car with 88K, and junked it with 175K) and all the engine's clearances were within factory specs, and the honing marks were still perfect. That to me says good stuff.benyandthejets wrote: I'm pretty cautious about using oil additives. You would think if they were as good as they claim to be, manufacturers would recommend them or they would be more widespread.
Hardly a conclusive test, without looking before hand or testing it on a bunch of engines its hard to say.Inodoro Pereyra wrote:I've used this one for years, and I've opened a B8 after using it on it for almost 100K miles (bought the car with 88K, and junked it with 175K) and all the engine's clearances were within factory specs, and the honing marks were still perfect. That to me says good stuff.benyandthejets wrote: I'm pretty cautious about using oil additives. You would think if they were as good as they claim to be, manufacturers would recommend them or they would be more widespread.
I'm not saying they definitely don't work, but I think I'll stick with normal oil.
93 Blaze Red GS
OEM 10w40
Works perfectly
Works perfectly
- AaronTietje
Sleeper6 wrote:I use the slippery kind
Vegetable oil. lol
- mazda915
I remember I used royal purple for two years and the cams started ticking and also happened to my friends mx also used it the same amount of time I did I recommend using castrol oil recommend by oe manufacturer and iv used that oil since and never had an issue also lucas oil treatment is good also .
1992 gs k8ze . 4 inch tip 2.5 cat , cold air intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
