KL-DE Swap no start
Thefez
Re: KL-DE Swap no start
its running now kinda shaky still tho need to get 1 or 2 more vac leaks fixed and im running a KL-01ECU and KL-02 VAF
Check that your injectors are both plugged in and that the plug is firmly seated. Having only one bank of injectors working will result in a shaky engine.
RobMinhas
If your injector rail is unseated you might notice some fumes coming out from under them, if your vac lines are messed up it could be that someone had been messing around with them and may have unbolted the rail(s) too and not properly installed them.
Thefez
I had to order new Intake mani gaskets so i have new injector O-rings so im gunna take the manifold off and replace all the vac lines with new lines and replace my VRIS solinoids with working ones and extend my harness for the VRIS conectors and everything should be good. I just drove the car for the first time tonight and it was amazing! i love this KL
