Dan's 94 RS, BP swapped and soon to be boosted 1/25/2014
- MazdaMan1991
Re: Dan's Boosted B6 MX-3 Project
so recently my anti drop bracket snapped during some colorful driving tehehe anyways here was my quick solution for a fix till i get the OEM bracket
snapped bracket (linkage being supported by jackstand)
flipped around and bam! fixed
My Mazdas
2008 Mazda 3 FS auto - Totaled
1994 Mazda 626 KL 5 spd - sold
2002 Mazda Millenia S - sold
1994 Mazda MX-3 RS 5 spd - bp swapped
My Worklog/Build Thread
My YouTube Page
My YouTube Page
- MazdaMan1991
heres me turbo setup, should be up and running by May, USDM VJ-14 with 323 gtx manifold and downpipe
My Mazdas
My YouTube Page
My YouTube Page
Is that manifold from the 323 GTX with the b6t? If you decide to go for a bigger I'm almost certain that a Vj20 or VJ11 should bolt up on that manifold.
And have you picked yourself up some upgraded injectors? What are you gonna run for engine management?
- MazdaMan1991
yep the vj20 will bolt right on and i plan on running megasquirt and not sure about the fuel injectors yet
My Mazdas
My YouTube Page
My YouTube Page
How much boost do you plan on running? I've heard of guys running BP or F2T injectors on BPTs at low boost so it might be something comparable there.MazdaMan1991 wrote:yep the vj20 will bolt right on and i plan on running megasquirt and not sure about the fuel injectors yet
- MazdaMan1991
well until i switch over to head studs, install a miata crank and flywheel and some better compression pistons, im only gonna run 8.5 lbs of boost, i believe thats what the stock waste gate is set to, then after the motor is bulked up and megasquirt is installed ill run i nice conservitave tune at probably 10 or 12 lbs of boost, this is my dd after all lol
My Mazdas
My YouTube Page
My YouTube Page
- MazdaMan1991
sure docrazycanadian wrote:
Sounds like a fun build bud... Welcome to the forums, do you have any pictures??
My Mazdas
My YouTube Page
My YouTube Page
- MazdaMan1991
so my tranny went out after taking it apart found out the diff was bad, ill put up pics, and do a little write up on how to remove your tranny, anyways i threw in my spare tranny, adjusted my clutch and its been driving well ever since, when the car is cold, it grinds going into reverse and thats it!
My Mazdas
My YouTube Page
My YouTube Page
The thing about that anti-drop bracket is that once the rubber has come apart int here you're losing all the anti-vibration that it was designed to provide.
Mine fell a few years ago so I went to the wreckers and found that the Extension Bar is the same in all MX-3s and 2nd gen progetes. Part #23 in this picture...
http://www.mx-3.com/manuals/showimg.php ... J1-054.gif
Very easy to change and a better solution than the anti-drop bracket.
- MazdaMan1991
yeah im in the works of getting a whole new oem shift linkage from mazda, and im about to get the corksport solid shifter bushings
My Mazdas
My YouTube Page
My YouTube Page
- Josh
The CS bushings make for amazingly nice shifter control Just do not tighten them too tight. It will get really stiff.
- MazdaMan1991
yeah it does hopefully theyll be here soon and im currently dicking with the drop bracket, its starting to bend backwards and my shifter is slowly dropping
My Mazdas
My YouTube Page
My YouTube Page
The stock GTX runs around 8 pounds of boost, but you'll find if you open up the exhaust, and intake you might end up with boost creep... The waste gate on the VJ14's is really small... while you have it out, try and port it.. This will help you have better control...
- MazdaMan1991
sounds like a good idea, now remember for now this will only be running on stock internals and stock head bolts lol so i cant go to nutscrazycanadian wrote:The stock GTX runs around 8 pounds of boost, but you'll find if you open up the exhaust, and intake you might end up with boost creep... The waste gate on the VJ14's is really small... while you have it out, try and port it.. This will help you have better control...
My Mazdas
My YouTube Page
My YouTube Page
- Josh
Just depends on how many miles are on your engine and how it has been taken care of. The stock internals are amazingly strong, you can boost up to 14psi which is pretty much maxing that little turbo out all day long if you have it tuned properly. The B6DE makes way more power than the GTX with the same turbo. The ports on the DE are much much larger. I would highly recommend port matching the exhaust manifold to the head. This helps a ton!. You should easily see 160-170 to the wheels on 8psi.
