The right Combination of parts fo the KLZE
- Newfie_dan
Re: The right Combination of parts fo the KLZE
you can't chip a obd2 comp from the 96 mx3 gs either which sucks for me cause I got a 96 obd2 gs.
You should be able to run MSnS on an OBD-II car with no problems with better results...I think...
First contact Ryan (probinator) on the Probe site and let him know you have a curved neck KLZE in an MX-3. He'll ship you the chip for $45. You have a 93 so your ECU should be chipable. If the top circuit board is sorter than the bottom one in your ECU it's chipable for sure.
As far as the 96 OBD2 goes use the KL02 VAF and your engine will run nice.
