Page 2 of 2
Re: Clogged CAT?
Posted: May 28th, 2008, 1:26 am
by umcamara
Mnemonic wrote:run the car for a little while, jack it up, grab the long handle breaker bar, it'll pop loose
let it cool then go with a regular ratchet
That's a smart idea, just run the run car for awhile instead of using the torch to heat up the bolts. Only downside is, now everything's hot, and you gotta be a little bit more careful.
Re: Clogged CAT?
Posted: May 28th, 2008, 3:46 pm
by fowljesse
A hollowed cat flows better than a new one.
Re: Clogged CAT?
Posted: May 28th, 2008, 8:44 pm
by fighttillyoudie0
fowljesse wrote:A hollowed cat flows better than a new one.
When the CAT is Hollowed out does the Diameter of it affect the backpressure in anyway?
Or is the cat the same size as the pipe it's connected to?(Like meaning when hollowed it would be like a straight test pipe?)
Re: Clogged CAT?
Posted: May 28th, 2008, 9:54 pm
by Ryan
aerodynamics is a very complex science... the movement of air has to do with diameters, the way the diameters change, the frequency of the pressure changes, the amplitude of the pressure changes, temperature, temperature changes, the curves.... lots and lots and lots. But sometimes a bigger path isn't neccesarily the easier path.
Personally, for all the difference a cat may or may not make, I would keep it, to help with things like passing emissions, and maybe saving the environment, if you believe in that.
But clogged, yes, I would think that would sap performance. Clogged exhaust should act similar to clogged intake, I would think, which I know can kill vehicles....
Re: Clogged CAT?
Posted: May 28th, 2008, 10:03 pm
by fighttillyoudie0
Ryan wrote:aerodynamics is a very complex science... the movement of air has to do with diameters, the way the diameters change, the frequency of the pressure changes, the amplitude of the pressure changes, temperature, temperature changes, the curves.... lots and lots and lots. But sometimes a bigger path isn't neccesarily the easier path.
I would like to keep it the way it is, but I do believe it is clogged... Which is really eating at the performance of my car. I had a bad oxygen sensor and my car was running pretty rich for quite sometime. I'm sure enough time to fowl it... So yeah...
Re: Clogged CAT?
Posted: May 31st, 2008, 4:25 pm
by fighttillyoudie0
Okay... So I can't get one of the nuts completly off. It will come off half way the it gets like stuck and won't come off any further. Is the threads stripped? or maybe dirty? Has anyone else had this problem before?
Re: Clogged CAT?
Posted: May 31st, 2008, 7:14 pm
by fowljesse
Yes. You'll probably have to cut it.
Re: Clogged CAT?
Posted: June 8th, 2008, 11:35 pm
by fighttillyoudie0
So I heard that if you put your hand over your Exhaust pipe that the backpressure should be enough to push your hand right off the pipe? Is that true? Cuz' if it is then my CAT must be clogged because I can put my hand over my exhaust pipe with hardly any pressure pushing on my hand.
