Posted: December 6th, 2007, 10:20 pm
The difference is the duration Jaun... If you are going turbo, there are turbo grind cams. but if you wanna b cheap use kl31 cams for your intake and kl01s for the exhaust (for boost)
I called them and they don't have any cams to supply so we would have to send ours in as cores to get worked on.96mx-3 wrote:if i am running a de.. i was either going to go with ze cams or colt street cams... but there a bit beefier then ze cams ? can my heads handle it ?
