who actually HAS an over bored TB?
				Gro Harlem
I had one. It cost me about 250ish i think....45 for the t/b & about 205-215 to ship it & have it reshipped back to me via a probetalk groupbuy wayyy back in early 2005.
It was a KL47 millenia throttle body that was bored to 67mm.
I got it back with the butterfly welded to the shaft, and i could see a bit of light through the bottom of it. When i installed it...it wouldnt' idle below 1200 no matter what I did, so I ended up fixing it by dabbing some silicone sealant on the edge of the butterfly plate to fill the gap. worked like a charm, could set the idle to 700 no probs.
As for power, I noticed no difference at all even at high RPM. Forced induction I hear these help a lot, but NA I didn't see any improvement (never dyno'd but i heard claims of 8whp at high rpms, which i should be able to feel).
Since it would occasionally have erratic idle I decided to revert back to a stock T/B & sell the 67mm bored unit...i forget how much i sold it for but it wasn't at much of a loss, if any.
DONATE TO MX-3.COM
						DONATE TO MX-3.COM
That's not the TB i got from you, is it?Gro Harlem wrote:I had one. It cost me about 250ish i think....45 for the t/b & about 205-215 to ship it & have it reshipped back to me via a probetalk groupbuy wayyy back in early 2005.
				hgallegos915
w00t my throttle body is done, i shoiuld get it sometime this week.. w00t.. i hope I dont have idle issues.. on the other hand..i was looking at a millenia manifold and the tb did not say the same codes as mine.. it looked different.. odd.
							-hec
so I finally got around to taking a pic of my big bored TB.  It is from a k8...  if my math is right it is in between 69 and 70 mm... it was right over the 2 3/4 inches mark on the tape... so 2.54 cm x 2.76 in = 7.01
if my calculations are off please correct me! either way - it's BIG!
yeah I think I need to use a different (more accurate) tape measure too
the little steps are not even that big of a player... the angle from which I took the picture does not do it justice and makes them look more raised than they actually are... but you are probably right it's probably only 68 mm max... *sighs*
I think I rememeber reading that the kl series TB's could only be bored out so far but the K8 could be bored further...I could be wrong...
here's my stock k8 TB on my other car... you can see the potential...
