3 1Tunes67 wrote:3 1
4 2
If thats your firing order.. assuming thats representing the 4 corners of your distributor cap.. then it looks like your distributor or firing order are 90 degrees off.. at least according to the diagram below found on page G-29 of the online manual.
You should be seeing
1 2
3 4
Cheers
Tunes67
4 2
is the correct order - the manual is wrong on that one. Chiltons shows the correct order.
Bumpy - Have you tried blocking of EGR?
