Page 2 of 2
Posted: May 6th, 2005, 2:42 pm
by What
Actually, if you're serious about having some fun, I think I may have a cold start injector from long ago if I can find it... it was attached to a stainless braided line to a common fitting for a fuel line on a Swift.
What are their timing 'reccomendations'?
Posted: May 6th, 2005, 8:03 pm
by Rick Johnson
Yea I was thinking about the cold start injectors, Gus Mahon style, I just found out he's dead, and died a while ago, while I was talking to a dodge nut with a pretty nice turbo shadow. Apparently it was a motor cycle accident, and Cam waugh bit it pretty good to in regina on a minibike awhile back, they thought he was braindead for a while there, but he's back at it again. I know I would kill myself if i got a bike, so I stick to cars.
Anyways ya if you could donate/loan/sell me the injector that'd be great, I just got the car off the stands I'm going to put the o2 sensor right after the y-pipe/cat flange.
Regarding the stock pump, I'm not sure I will keep it or not I doubt it's any good past 200whp, things will probably get pretty lean around the #6 cylinder if I keep it, and if that thing even hiccups when spraying....bang!
I went out to race city on april 22nd with the SRT-4 and ran a 14.3 completely stock, the best time I've heard of/seen is 14.1 with decently done up SRT-4, I even beat a stage 1 there my first race
![Twisted Evil :twisted:](./images/smilies/icon_twisted.gif)
Posted: May 7th, 2005, 10:10 am
by What
A friend of mine was talking about a bunch of SRT4s that showed up at the track one day, I was wondering if you had went down.
I'll try to look for that injector today, I rough idea of where it should be in the mess of the garage.
Posted: May 7th, 2005, 1:13 pm
by Rick Johnson
Yea I was there on the 22nd racing and there was a bunch 6 maybe. hopefully late aftenoon today I can get a start on the wideband install. As far as timing goes I should be retarding it 4 degrees for 75hp. IF I get a bigger jet I'll probably go -6 for a 125. The tricky part is making the timing stick.
Posted: May 7th, 2005, 2:52 pm
by rebel2k4
Hell yeah, sounds like some good stuff. Keep that thing really rich and like another said, hit it at high rpm's never low.
I have safely doubled the HP on my KL (over 300 at the crank) with absolutely no problems. Been beating on it for like 12k miles. I do run 11:1 AFR though. I run 3 cold start injectors and an FMU.
I think a dual stage 75 then 175 can be safely coaxed out of a K series V6. My turbo is the equivalent to like a 175 shot n20 or more, and my KL takes it great.
Posted: May 7th, 2005, 8:49 pm
by Rick Johnson
11:1 is super rich, but If i recall correctly your non-intercooled? Have you done anything for timing?
Posted: May 9th, 2005, 2:40 am
by Rick Johnson
I got the o2 bung welded in and plugged for now, but now I'm out of nitrous dammit. I need a gauge pod or something for the A/F gauge....
Posted: May 9th, 2005, 6:54 am
by rebel2k4
I havent done anything for timing. I am non intercooled, but I run water injection. It helps great with running aggressive timing and boost on pump gas and it cools the charge temps tremendously. But yeah, 11:1. Better safe than sorry. I learned that the hard way.
Posted: May 10th, 2005, 1:37 am
by Rick Johnson
Ok I just finished installing the Wideband Commander. Everything seems to be working, I haven't gotten all the analog inputs hooked up yet. At startup it's a little lean it seems, = 15.5ish and then once warm it's right at 14.7, on deceleration in gear its super lean, like 18. And when I punch it, it goes to about 11.5 Do these AFR seem normal to you guys? I think they're ok
The only reason why I ask, is that I have a few codes coming up, and today on my way home before the install, I got a CEL. and it keeps coming on, I checked my codes and it looks like the usual suspects:
02 'NE2' crankshaft position sensor
10 Intake air temperature sensor
08 Volume Air Flow sensor (VAF)
I'm going to bench test my VAF and see if it's running properly..... could just be a faulty ground or corroded terminals.
Posted: May 10th, 2005, 3:18 pm
by What
most imports run fuel cut on decelleration - no fuel injected. The max lean reading is 18:1 on the dynojet or it would actually read leaner than that.
