help with my BPT....oohhh the humanity
![Image](http://xs26.xs.to/pics/05172/disconnect.jpg)
Ok so there is it, that is the plug that came loose. I did what you said Franko and it started right up, idled fine and took gas like nothing was wrong, I even took it out and put it back into the garage.
I let it run for a while and the longer it ran the more calm the idle became, right back to normal. When I first gave it gas, it sounded kinda like you were hearing it through a fan, , but after a little bit, like a minute or so, it was fine!
I had no black smoke coming from the back, and the gauges were reading normal again.
Thanks! I am still going to have it checked, the axle still needs to be replaced, since I have it I am going to go ahead and change the O2 sensor, I will also have them check for the carbn build up and the other suggestions I got here. Soon as the mechanic looks at it I will report the findings!
![Image](http://i268.photobucket.com/albums/jj24/sigma31337/sgsig.jpg)
