[FS] 94 MX3 GS *Price Reduced*
That car is in rough shape for the $3700 asking price.
Good luck selling it
OSKY
95 MX-3 GS ZE Turbo: MSnS-extra, AEM WB, Blitz boost controller, MSD 6A w/ Blaster2 Coil, ZE disty, Redtops @ 550, Walbro 255, Garrett T3/T04E 60 Trim w/ .63 A/R, 38mm Deltagate Mark II @4psi, FMIC, Apexi BOV, CM Dual friction, 4-6.25 Kickers, 2ch Alpine V12. That's Alll.
http://www.pakfeifertuning.com
- ScooterBovine
RizzeRocket
The only thing wrong with the car is hhe front bumper lit cracked and needs to be repaired or replace. The price goes up if I get it certified because I know it will need a few things to certify like i think it could use brake pads, therefore it will be more it you want to buy it certified. I fixed it up before I'm selling because it would have been worth nothing with a slipping clutch. So I fixed it all and I am now selling it. And what I mean about pretty much everything in the clutch is perfect, is that I just got the clutch replaced. The clutch disc, release bearing, pressure plate, and slave cylinder was rebuilt.RizzeRocket wrote:ok now whats wrong with that car? price goes up if u certify it but you havent told us that there was any problem with it and why are u fixing everything up before sellin it? Pretty much everything in the clutch is perfect ??
I'm not exactly sure what it will need. It need two bolts in a bar underneath by the rear suspension, they are missing. Certification is usally about $60-$80 to get done and then plus more if it needs a few things. I know for sure it won't need anything big. And for $3400 it will also be e-tested which is about another $50 or so.
Thanks, Lee
Thanks, Lee
