look what I got today
Re: look what I got today
how much were the pistons/rods? they look beautiful by the way
ProjectMx
My BP and AWD build thread
Cardomain
93 Escort GT daily driving
Cardomain
- babyblueMX3
What's involved in micro polishing? never heard of that..I'll ask the shopOriginally posted by OsoSlo z28:
if you're going to have them mess with the crank, look into micro-polishing as well.
1300 usd$Originally posted by mazda78:
RIP 400whp ZE-T MX-3
Isn't micropolishing the crank almost like honing it to get more oil to the 6th bearing (Huge proble, with our car)
93 Kandy Tangerine Mx3 GS-DE
05 Saab 9-2x (Wrx power plant)
02 Subaru Impreza OBS
05 Subaru forester Xt - sti mods
04 dodge ram - toy hauler -FOR SALE
& Lots of Toys to haul![Very Happy :D](./images/smilies/icon_biggrin.gif)
Very sweet. Wish I had the money to get stuff like that. As is, though, the $100 I dished out to get used ZE pistons is alot for me.
Anyways, if that's a Cyborg kit, check the bearing clearances. There's a thread on Probetalk about bearings included in the kit not matching up right.
![Throw Up :throwup:](./images/smilies/throwup.gif)
- papa roached
- matt-gerrard
YERY NICE ...BLUE
I just love the cars that we have no matt-er(lol) how little or much you do to them there all so beautiful!Drive it, like you stole it!'92 gs V6
http://www.dfwmazdas.com/vbulletin/imag ... 1148070546
- babyblueMX3
[quote]Originally posted by lakersfan1:
Very sweet. Wish I had the money to get stuff like that. As is, though, the $100 I dished out to get used ZE pistons is alot for me.![Smile :)](./images/smilies/icon_smile.gif)
- babyblueMX3
hey guys I got a question..
while browsing toga's parts I noticed the mx3 and mx6/626 have the same main bearings but different rod bearings..
isn't the rods bearing suppose to be the same since it's the same crankshaft ?
and what are main bearings? You think I should buy them for my rebuilt ?
- mrspanky79
they are not the same crank.
kl03=74.2mm stroke
kl08=69.6mm stroke
the stroke is all in the crank. Plus k08 smaller bore so the rod end is going to be smaller to drop down the cylander=smaller bearings. You are going to need Main bearings, rod bearings, thrust washers and all the seals.
kl03=74.2mm stroke
kl08=69.6mm stroke
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
99 vitara 4x4
- babyblueMX3
good that answer 2 questions..and for the other..what are the main bearings..where do they go ?Originally posted by mrspanky79:
kl03=74.2mm stroke
kl08=69.6mm stroke
- papa roached
main bearing are what the crankshaft ride on
- babyblueMX3
k I just figured that out
what about thrust washers..what do they do..I feel kind of dumb asking all those questions
<small>[ November 10, 2004, 06:41 PM: Message edited by: babyblueMX3 ]</small>
all u need to prep ur engine for turbo is rods and pistons? (im talking about a 135,000 mile engine)
www.illegalCustoms.com
Tri-State Area Car Club
you dont need to do anything to "prep" it technically aside from general maintenance.... but you'll only be able to safely run low boost... the more you do to the engine the higher boost you can run... i'd rather go with b6t pistons which lower compression to 7.0:1 thought cause supposedly that means you can safely run higher boost.... but those wesico are bad...
ProjectMx
Cardomain
Cardomain
- babyblueMX3
I have a klze so no b6t pistons for meOriginally posted by mazda78:
7.0 CR must be so lame off boost
