FC turbo II intercooler?
illicitQ
Re: FC turbo II intercooler?
Post by illicitQ »
thats an idea.. but where would you have the space to mount the fan below the top mount? what I/C do you plan on using?
92 RS: BPT, evo front mount, custom 2.5 in IC pipes, apex-i SAFC- II, GReddy type-RS BOV, rear disc swap, GTX front strutbar, oem GS lower rear tie bar, Topspeed1 axle back exhaust, 15" TSW wrapped in yokohamas, power window swap. NOT INSTALLED: GReddy turbo timer and CS downpipe.
SE-Man
Post by SE-Man »
The fan would likely have to be put on top to avoid damaging heat of the engine during shut off, so It would have to be placed into the area of the scoop itself so you'd actually need a larger scoop then a STI/WRX scoop. But you'd get to keep the ultimat turbo sleeper look with a set up like that.
Return to “Forced Induction”
