13 second klze mx3??
Gro Harlem
Re: 13 second klze mx3??
i've see posts saying our flywheel is anywhere from 13-16 lbs.....although now that i think about it, it's probably the latter.
The fidanza makes your car rev like a motorcycle...if thats what you want, then go for it, there are downfalls htat i'm not willing to have in my car's driveability, the thing rev's plenty fast for my tastes.
DONATE TO MX-3.COM
DONATE TO MX-3.COM
TsiMiata
I drove a fidanza in an MX-6 for 50k miles. I never had any complaints. I think it really woke the car up. Never regretted it for a moment.
91 Eagle Talon Tsi AWD *RIP*
- millionflame
Well, you'll get considerably more engine braking with the fidanza. I know most of you know this, but some wont.
Makes shifting a little more "involved" but nothing drasticly horrible.
~A
~A
~ Millionflame (94 GS 120K)
- papa roached
i got mine brand new for $285, so im happy, still need my ZE to install, couldnt pass it up at that price
jdm_man
thanks for the suggestions guys, will high compression pistions do anything? does anyone make them for our an mx3??
jdm_man
also what do you guys think about he brullen cat-back exhaust?? if its brutal whats a good one???
aaronthehic
have you seen that setup to go that fast$$$$$$Originally posted by Illa Killa:
You can gut your car a bit and do some other engine work for 13 seconds all motor, you can go with nitrous to make 13s easily if you can drive or you can go get a turbo setup, boost about 9psi and break into the 12s like My_Probe_Is_Faster did on probetalk.com. Just gotta have some good traction and axles. Good luck.
he had a lap top there adjusting fuel maps
thats big coin
13.023 @ 105 mph
high compression goes well with agressive cams. both will give you good gains but if you have both your gains will be much betterOriginally posted by jdm_man:
mdavis
I honestly wasn't expecting much of a difference out of the Fidanza, but it really makes a very noticeable difference in acceleration, which I think is amazing. It really does make the care come alive. It also sounds amazing with a grounding kit. I was way sceptecal about that as well but the grounding kit makes the motor run so smoothly... i think both are well worth the money.Originally posted by Gro Harlem:
you aren't going to see much of a difference with the $350 fidanza.
you can't shave them much or they will warp and crack. ask babyblue, he had a 13.5lbs(?) and it broke after 4 months I think...Originally posted by thebonestockkid:
the stock fw is rated at 16lbs, you can shave it DOWN to 12-13.
<small>[ September 28, 2004, 03:07 AM: Message edited by: mdavis ]</small>
GS-R SE
Fixin's
- papa roached
grounding kit changed the sound of your car? i got a guy who drives a probe here and his got more high pitched
Thread from MX6.com about colt cams, and how much the cams cost.
Colt cams.com
<small>[ September 28, 2004, 03:59 AM: Message edited by: Talon_66 ]</small>
Colt cams.com
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
mdavis
Mine didn't get more high-pitched, just more smooth.Originally posted by papa roached:
I forgot to mention drivability with the Fidanza. I was actually pretty concerned about it. It's just as easy to drive as stock, though, I can't actually tell the difference between it and the MX-3 one in drivability. Maybe if you're a girly-clutcher you might have trouble coordinating it, or it might be more difficult with a k8, but really for a ZE it's no trouble at all.
GS-R SE
Fixin's
Nallboy
0:Millenia IM count?Originally posted by Gro Harlem:
IMO the cheapest way to approach 13's is to get the mods in this order:
0: KLZE manifold (if you don't already have one)
1: cold air intake
2: full catback w/free-flow cat
3: headers
4: regrinded ZE cams
5: motor mounts / poly control-arm bushings
1:check
2:coming soon
3:check
4:maybe later, way later
5:check
and some...but I still only expect a mid-low 14 on a good run
Also, does a ground wire kit really make that much of a difference? I'd never really heard much about them on this site before. Can't you make your own grounds w/out the kit, like a DIY?
'93 GS sporting 31 ZE, 36 ECU, Millenia IM & TB, Beefed up tranny, Fidanza FW, CM Stage II-R, Al UDP, HS Headers, MF Hi-Flow CAT, 2.5" Piping, CAI, MGC Wires, MS Mounts, B&M SS, Bronzoils, SS B & C Lines, Brembos...more.
Oh yeah, I have a stock ATX 92 RS too.
"Everyone wants to live life in the fast lane; I have more fun weaving through traffic."
TsiMiata
Any autoparts store will sell ground straps. Buy a couple for a few bucks and have a blast. I persoanlly think they make no difference. The only one that really counts is the one from the battery to the body. The motor is ground nine ways till sunday and ading another strap I doubt does much.
you could prolly gain a lil more hp w/some 11:1 CR pistons, and maybe a stroker kit...but who knows who makes one of those. probably have to be custom. but if youre wanting to build up the motor w/o FI, go for it!
