So, my electrical stuff in the car is now finished and wired up.
The engine was in and for a moment started. Besides of a faulty TPS sensor (easy fix) I've been fighting against a coolant leak !!
![Crying :crying:](./images/smilies/crying.gif)
Terrible !
It appear the engine had some broke bolts, one of them being the coolant piping at filling neck to the bottom end. I took a chance with gasket sealing and I failed.
Take all the timing stuff off, intake off, pullies off etc
Got a helicoil kit, fixed that leak.
Than the leak from the "feeding" pipe towards the oilfilter housing started leaking.
Replaced that O-ring and continued.
Now I'm at (I hope) my last leak. It seems either rear bank head gasket or Block heater block-off plate.
Put some UV-dye in the system to find it, but off course, now it's not leaking anymore.
Ow.. and some powder coated valve covers for the KLDE.
![Image](http://i292.photobucket.com/albums/mm12/robertsandiego/Rebuild/KLDE/Poedercoat%20kleppendeksel_zps1csko2nk.jpg)
