WhiteFinish's Log there we go again
WhiteFinish
Re: WhiteFinish's Log It's all about the wires.
Post by WhiteFinish »
Several updates
After a very very long search I've found some brake disks that fit the Mazdaspeed 6 calipers.
Powder coating several things and reinstalling
Crossmember installed
Tiebar
Whiteline swaybar
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
WhiteFinish
I couldn't resist anymore to buy some cusco camber plates.
After some good searches I've found a good deal on a new front set, + another deal on the rear set.
Now just to wait for them to arrive.
Worklog click
weede_klze
Post by weede_klze »
keep posting, I like it :)
WhiteFinish
Re: WhiteFinish's Log powdercoating and cusco
Cusco Camberplates came in.
Just left; installing them.
Also created adapter rings for my new brake disks.
Next step; fitting them accordingly.
Worklog click
WhiteFinish
Installed the cusco's on 3 of the 4, than I had to go for an appointment.
The rears need to move the bolts from the most outer hole to one more inner, otherwise they'll hit the body.
End result
Also had to fix some rust on the passenger side. (or well, my welder)
Worklog click
mars
Post by mars »
WhiteFinish wrote:Installed the cusco's on 3 of the 4, than I had to go for an appointment.
BIG MISTAKE ! you have to turn plate 1/4 !!!3
Hope you can see what I mean here :
Camber is made by different position of the plate from outside the car to inside NOT from rear to front !!!!
WhiteFinish
You're absolutely right !
Probably after a long day i didn't realize.
Worklog click
Good catch, life is better when we're not on the dope. :lol: :wink:
WhiteFinish
Started rebuilding the interior after the welding is finished.
Xenon put in a 'hidden' place
Worklog click
Sleeper6
Post by Sleeper6 »
wow missed these updates.. what rotors did you end up using? Like the powder coat but howld the O ring fair for the coolant transfer pipe?
WhiteFinish
I will update the Brake disk part once I've actually driven the car
Don't want to start talking about something that hasn't been proven yet.
Powder ocating that tube, I don't know. Let's see what weill happen. I think it's fine.
Worklog click
WhiteFinish
Of course did some more work:
Remounted new balljoints, tierods etc
From a good friend I received a set of Ford Escort ZX2 trailing arms
Mx3, measured the narrow end.
Zx2
Strange thing i don't understand yet. The Mx3 and ZX2 on top of each other. Yet the mx3 seems wider.
Master brake cilinder (millenia) where I accidently had the 2 tubes reversed.
New piece of cable to finish up the wiring of the subs.
Worklog click
WhiteFinish
Re: WhiteFinish's Log re-installing again.
So, my electrical stuff in the car is now finished and wired up.
The engine was in and for a moment started. Besides of a faulty TPS sensor (easy fix) I've been fighting against a coolant leak !!
:crying: :crying: :crying: :crying: Terrible !
It appear the engine had some broke bolts, one of them being the coolant piping at filling neck to the bottom end. I took a chance with gasket sealing and I failed.
Take all the timing stuff off, intake off, pullies off etc
Got a helicoil kit, fixed that leak.
Than the leak from the "feeding" pipe towards the oilfilter housing started leaking.
Replaced that O-ring and continued.
Now I'm at (I hope) my last leak. It seems either rear bank head gasket or Block heater block-off plate.
Put some UV-dye in the system to find it, but off course, now it's not leaking anymore.
Ow.. and some powder coated valve covers for the KLDE.
Worklog click
marcdh
Post by marcdh »
Great work and perseverance! Keep up the good work.
View Worklog
DeadMaker
Post by DeadMaker »
Do you think zx2 trailing arms are better?
Does it worth?
Black Mazda Mx3 Rs 1997 B6DE
