Interchangeable trannys for sohc
does anyone know what transmissions will bolt up to the B6 SOHC 1.6? Thanx alot
Re: Interchangeable trannys for sohc
There is a fair amount you can find with search. The key information is that your stock tranny is an "F" series. There is also a "G" series that is beefier, but swapping also requires the flywheel, clutch, and axles, and perhaps more. These are manual trannys. I don't know about automatics.
