Oil weight?
- papa roached
Re: Oil weight?
so the 5w-50 i was running for 3000 miles is to much?
Re: Oil weight?
everyone just change to synthetic oils... please :p
- papa roached
Re: Oil weight?
i do run nothing but synthetic
