properly resetting the ecu
I searched the forums for how to reset the ecu. I've found so far 3 different ways.<p>1 - Disconnect the negative terminal, hold the brake for 15 seconds<p>2 - Disconnect the negative terminal, hold the brake for 30 seconds<p>3 - Disconnect the positive terminal for 15 minutes<p>Which way is the correct way to do it?<p>[ June 24, 2003: Message edited by: maxx ]</p>
Re: properly resetting the ecu
all are right, some are just quicker then others
1993 MX-3 GS V6 - Stock
2004 MazdaSpeed MX-5
2004 RX-8 - Project
2004 RX-8 - Project
Check engine light??<p>96 MX3 4 cyl had bad spark plug and now Check Engine light is on.<p>Do you reset ECM to cancel light??<p>appreciate a reply to fix this.......<p>thanks.
swifty..
swifty..
- Custommx3
- Site Administrator
to clear all your engine codes, yes, you reset the ECU.<p>[ June 24, 2003: Message edited by: Custommx3 ]</p>
Len-Dogg
Yes they are all correct. What pushing on the brake does it run all the electricity out of your car faster. Even when you disconnect the battery some energy remains in the system. So pushing on the brake lights up the brake lights, and thus runs this left over energy out faster than waiting for it to dissipate on it's own.
1995 Blaze Red RS 5sp. Manual, Pacesetter Exhaust, Custom CAI, 17" ADR Rims, Kumho Tires, Altezzas, GS Style Spoiler and Mud Guards, Neoprene Seat Covers, Aluminum Foot Pedals, Leather Shift Knob, Remote Starter, Blaupunkt Stereo and 5-disc changer, Pioneer Speakers, Amp, and Sub<p>http://www.cardomain.com/id/lendogg<p>http://www.msu.edu/~leonar40/Car.html<p>
Because whatever is causing the light to be on is still wrong. Fix it, clear the ecu, and the light will be off.
My Cardomain site
My Cardomain site
