What is a best Wire Set?
raiden
Post by raiden »
I want to know.What is a best wire set?- NGK,Nology,Bosch,MSD and MAGNECOR.... If I want to use with 1995 Mazda MX-3 DOHC 1.6L ....???
Chutipong Ampornpan
Black 1994 MX-3 GS Auto.
theo
Re: What is a best Wire Set?
Post by theo »
Hey I also have a 95'1.6L DOHC. I just ordered a set of Magnecor from an import shop where I live in Kentucky. They said they are awesome plugs, esp. for the price.....Nology are way too expensive...I wouldn't buy those unless i at least had the 1.8L. just not worth it...what do you have done to your 95?<p>theoyork7@cswebmail.com<p>theo :shrug:
cjthor
Post by cjthor »
What does displacement have to do with wires? I have the 1.6 and have the Nology wires and beru sparkplugs. I did notice a difference in idle after installing. Seemed to rev up a little smoother too if I recall. Definately a little pricey but I heard that they were worth it and they do seem to work good.
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
jspecmazdaman
Post by jspecmazdaman »
I got the 9.3 mm apc plug wires(which i believe are the biggest made) and NGK V-power plugs cant really tell much of a power difference but the car runs alot smoother with them.
torpedan
Post by torpedan »
i used to run 8mm MSD wires with KNG iridum plugs.. Ran farily well and all but i have yet to start the work on my 1.8 as of budget constraints, but i am considering following in the same path.
-torp.
I don't own a Mazda.
azmtbkr81
Post by azmtbkr81 »
Doesn't the MX-3 come with NKG wires stock?
'94 Blaze Red RS<P>I may not have a lot of horsepower but I know how to use it!
