4-puck isn't that bad
Shady469
Post by Shady469 »
well, my clutch went out and i had my ACT that i was saving until my B6T swap layin around and didnt have enough $ to buy another stock clutch so i put the ACT(4-puck w/ extreme pressure plate) in my SOHC.<BR>there is no play what so ever, and stop and go driving is a huge pain, but it grabs HARD and made the car funner to drive(IMO). its not as bad as i thought it was gonna be; I dont think its harsh enough to break anything. but i would NOT recommend this clutch for a daily driver unless it was necessary. oh well just thought id share.<p>[ November 23, 2002: Message edited by: Shady469 ]
B6T powered MX-3 - sold
Stage 3ish 03 WRX - sold
03 S2000 - current/ for sale
boostedmx
Re: 4-puck isn't that bad
Post by boostedmx »
ur gonna have elephant calves in a month!! :D :D :D :D
DRAG SPEC MX3 BEING PARTED OUT.
BUY ALL MY STUFF OR DIE.lol, SERIOUSLY BUY MY STUFF. PLEEEASE
killerpickle
Post by killerpickle »
sprung hub?
Tom Alexander
JWMotorsports
Post by JWMotorsports »
The ACT 4puck doesn't have a prung hub, hints the reason ACT named it RACE ONLY. Well Shady...it will be fun for a while, but it's only a matter of time before you'll break something. I broke a differeitial & 2 CV joints with the stock clutch. Then I swaped in the B6T & broke another diff in another tranny. To help make it last the longest possible life, spin as LITTLE as possible & avoid wheel hop at ALL costs. I used to love burnouts...untill I heard snap n pop there goes the drive train....again! Good luck...hope you don't suffer my misfortions.
rikymaru
Post by rikymaru »
Good ol' FWD trannies....less to break. ^_^<P>Which ACT is it? Because the 2100 4 pucks are actually nicer on a tranny than the heavy duty 3100 street clutches (why someone would need 3100 pounds of clamping force for a street car is beyond me; I mean, people run 10's on the 2800/Stage 3s)<P>But be prepared to break something.
Elena, don't misunderstand. A pro isn't someone who sacrifices themselves for their job. That is just a fool.
JWMotorsports
I might end up useing the ACT "Tranny Breaker" pressure plate w/ a street disc in my car later in life when it's done. Ofcoarse I'm looking at around 500-550WHP (goal is 550-600HP to flywheel), a cryo treated tranny, & custom "Drive Shaft Shop" axles made for 600HP. Who knows...I might need the hubs too! I haven't decided what to do about the differential yet. ;)
