rough idle...
templar
rough idle...
Post by templar »
hey everyone, my car is idling kinda weird. it drops below 1k rmps when im sitting still in nuetral and shudders like it wants to stall. I'm going to replace the oil and spark plugs since I just bought the car and I'm not sure how regularly it was maintained before I bought it. Any other ideas on what else to do? Thanks!
OsoSlo z28
Re: rough idle...
Post by OsoSlo z28 »
check vac hoses for cracks/leaks.
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
Stevech_2001
Re: rough idle...
Post by Stevech_2001 »
also clange your air filter or put a cone one on your maf
Steve
templar
Re: rough idle...
Post by templar »
thanks!
fernando
Re: rough idle...
Post by fernando »
try to do a tune up it could be that.
jinu_chang
Re: rough idle...
Post by jinu_chang »
Could juss need a engline flush. My throttle plate was clogged with carbon build up. So I got a engine flush which finally did the trick for me. I did replace the o/2 sensor, plugs,wires, fuel filter,pcv valve and erg valve before that though. Turns out juss needed a injector flush.
