oil pressure gauge
- millionflame
oil pressure gauge
Hey,<BR> Does an oil pressure gauge tell you how much oil you have, and when you should add more oil (instead of checking the dip-stick) ??? Or, does it do something completely different???<P>Thanks, Aiden.
~ Millionflame (94 GS 120K)
Re: oil pressure gauge
It tells the pressure of the oil
Putter...Putter...Putter...
The Unstoppable MX-3 GS
- millionflame
Ok then, so what gauge would tell me the oil level???<P>~A
Ryan Bowen
There is not a gauge for that. You will have to manuelly check oil, for the best resaultes check the oil when the car is cold. This will give you a good idea of the amount of oil in the car. I check my oil every morning that is because I love my ride but you can do it every time you fill with fuel. This way you know if it is low or not also you can tell if it is dirty or not.
- millionflame
rayrrod
If u have a oil pressure gauge,( I Have idiot lites) then get to know the oil pressure at different speeds and tach readings and at different gears.<BR>BTW where did u mount the oil pressure gauge?
- millionflame
If you're asking me, I put it in an a-pillar mount.<P>~A
