Who has a BPT swap?
Brainless
Who has a BPT swap?
Post by Brainless »
I'm looking for someone who could help me doing my own BPT swap by giving me some info about their own experience.<P>please email me<P>thanx :)
Jonathan Michaud
93 Red RS
OsoSlo z28
Re: Who has a BPT swap?
Post by OsoSlo z28 »
<p>[ October 06, 2001: Message edited by: cre8v mx3 ]
"MR." Ashley Fowler
'02 Yamaha Warrior (1700cc)
'94 MX-3 RS-t (BPT)~ sold
cardomain pics
OsoSlo z28
<A HREF="http://www.geocities.com/bat_elof/bpt.html" TARGET=_blank>http://www.geocities.com/bat_elof/bpt.html</A> <P>how much are you wanting to spend? if you have about a grand more, get the bpd. that's what i'm doing in about 2 months(install is the same between the two)
"MR." Ashley Fowler
cardomain pics
Brainless
Post by Brainless »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by cre8v mx3:<BR><STRONG><A HREF="http://www.geocities.com/bat_elof/bpt.html" TARGET=_blank>http://www.geocities.com/bat_elof/bpt.html</A> <P>how much are you wanting to spend? if you have about a grand more, get the bpd. that's what i'm doing in about 2 months(install is the same between the two)</STRONG><HR></BLOCKQUOTE><P>BTD? is that the AWD version? Must be hard to convert a FWD to a AWD. :eek:
Jonathan Michaud
93 Red RS
Brainless
Post by Brainless »
ooopps I meant BDT. :roll:
Jonathan Michaud
93 Red RS
OsoSlo z28
yeah, the only thing that needs to be done is the drive shaft. you have to use the BPT/BPD joint shaft bracket(motors are the same externally)and the mx-3 shaft. the only problem is it's about a 1/2 in. too long. shouldn't be too hard to do. but yes, they are both awd cars. the tranny mounts up other than that. holds up pretty good as well. you'll also need a bigger fuel pump, boost controller, apex'i SAFC, custom down pipe(new exhaust recommended), upgraded clutch(stage 2 or 3, depending on the motor you go with), an intercooler(you'll need a bigger one for the BPD than you would for the BPT),and i believe you'll need a blow-off valve, and a air/fuel gauge and a boost gauge. the car will do fine with the stock ecu and harness with the piggy back boost a air/fuel controllers. but it would be best to get the ecu and harness. if you live near a port you can get a package deal(motor, ecu, harness, and all sensors) from australia shipped cheaper than just the motor shipped from cork sport. just my .02
"MR." Ashley Fowler
cardomain pics
Custommx3
Site Administrator
Post by Custommx3 »
What I dont understand.. <A HREF="http://www.geocities.com/bat_elof/" TARGET=_blank>http://www.geocities.com/bat_elof/</A> <P>he sapped auto to manual.. bit he used a 1.6L i believe tranny.<BR>now he states he used a 1.8L motor. Did he use another tranny when he did this swap? Did I mesread or overlook something?
OsoSlo z28
he swapped in a 1.6 mtx cause at the time he had a custom b6t. when that motor messed up, he swapped in the BPT and kept the "stock" 1.6 tranny
"MR." Ashley Fowler
cardomain pics
Custommx3
Site Administrator
Post by Custommx3 »
Um the 1.8L requires a 1.8L tranny from a Protege, I believe.
OsoSlo z28
correct if i'm wrong(cause i'm not 100% sure here) the escort/protege use the same motor as the n/a bp series motor but they also use the F25M-R tranny...same one that's in the mx-3(4cyl). the stock tranny from the mx-3 "will" bolt up. i e-mailed the guy at the link above and he told me that he used the stock tranny. he also said he talked to a mazda tech and was told these tranny's are very strong. i'm curious if the mx-3(v6) tranny will work. i haven't looked at one though
"MR." Ashley Fowler
cardomain pics
Brainless
Post by Brainless »
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by cre8v mx3:<BR><STRONG>correct if i'm wrong(cause i'm not 100% sure here) the escort/protege use the same motor as the n/a bp series motor but they also use the F25M-R tranny...same one that's in the mx-3(4cyl). the stock tranny from the mx-3 "will" bolt up. i e-mailed the guy at the link above and he told me that he used the stock tranny. he also said he talked to a mazda tech and was told these tranny's are very strong. i'm curious if the mx-3(v6) tranny will work. i haven't looked at one though</STRONG><HR></BLOCKQUOTE><P>Does both 4 cyl. (SOHC ET DOHC) use same transmission?<BR> :roll:
Jonathan Michaud
93 Red RS
OsoSlo z28
as far as i know...yes.
"MR." Ashley Fowler
cardomain pics
natural born honda killer
Post by natural born honda killer »
i talked to derrick at corksport and he said that for the BPT i think (the 180 hp one) that you need to have the ecu reprogrammed and a transmission from a 90-94 DOHC protege. he said that it should just bolt up and that you dont have to do any suspension mods. the only thing i was wondering was if the protge 90-94 DOHC tranny have better gearing than the mx-3 4 cyl DOHC. i plan on doing this swap probly next summer when i get enough $$$$$.<P>jerome cline :D
jeremy cline
95 MX-3 RS
The only BPT GTR MX-3 in Texas!!!
man iraq sucks!!!
OsoSlo z28
i think it might have slightly better gearing since the motor has a higher output vs. the 105hp of the mx-3 DOHC. but the swap is not "needed".
"MR." Ashley Fowler
cardomain pics
