I know people say th kl header will fit the k8
But from the head to the block do the ports match up or does it leak
Or would it be better to just cut an weld the original ports back on the new header
Kl header on a k8
- MazdaRider
Re: Kl header on a k8
works fine, have one on mine since my KL went south. Only thing you have to fab up is to re-position your convertor about 6" back
I modify my ride so I can drive around the stupid people ![Very Happy :D](./images/smilies/icon_biggrin.gif)
- MazdaRider
So no need to modify the flange to the block even the gaskets are fine
Everything manifold to block is the same.
Some headers will hit the bottom of the oil pan, if so just add 2 1/4" 3 bolt metal flanges (one front one rear) between the down pipes and the cross over pipe and that'll give you a little clearance.
