Fidanza flywheel
- mx3_ryder
Fidanza flywheel
Thinking of purchasing a Fidanza flywheel and was hoping for some honest reviews and opinions from those using one.
I'm currently running the lighter mx3 flywheel on my ZE so would it be beneficial to go lighter?
I do not drag race, but love to "bang through the gears" on the street and hardly ever drive in slow traffic.
What does it feel like driving our cars with a lighter flywheel compared to stock?
Re: Fidanza flywheel
Motor will spin up even faster. Noticeable difference.
							1 mx6 88 LX auto 2.2l 4cyl
2 mx6 93 LS saved from junkyard SOLD
3 Mx6 96 M edition blow a ze part it
4 Mx6 96 gold LS paint n lights auto SOLD
5 mx6 red fresh paint clean, sold
1 mx3 92rs sohc auto rota c8s h&r
2 mx3 93 gsze bought w/ mods
3 mx3 93 GSze mtx swp act stg3 str8 nek im eibach kl36
4 mx3 GS SOLD-
6 mx3 white gs jdm swap'd SOLD
*5th mx3 blk GS clean title modded DD*
1 PGT 97 blk, garaged clean sold
2 pgt primered 5 spd KL SOLD
4 mx3 GS SOLD-
- mitmaks
You could shave your stock one and save quite a bit of weight that way.
							Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE  '95 Cobra SVT #2722 '68 Charger R/T 440
				crazycanadian
It's very worth well mod... fidanza is also a much better brand to go with over other brands... fidanza is the only company that makes the friction surface replaceable by bolting it on...
I have run fidanza flywheels now on both my 323 gtx and my klg4 swapped 323.... well worth the money
I wen't from, stock mx-3 to chromoly.
Stock was: 16,5 Lbs
Chromoly is: 12 Lbs
Fidanza: 9 Lbs
I tried the chromoly first, cause it was like only $100, but i don't think u can get them anymore.
I like it very much, was concerned about a rough idle but there nu difference.
Next time i get in there i will bolt up a fidanza.
						Stock was: 16,5 Lbs
Chromoly is: 12 Lbs
Fidanza: 9 Lbs
- MrMazda92
Revs up faster, and down as well.
You'll notice the same difference in acceleration as you would by dropping 5-6 pounds in wheel weight.
- WhiteFinish
You also have the Aasco flywheels with a replacable friction surface.crazycanadian wrote:It's very worth well mod... fidanza is also a much better brand to go with over other brands... fidanza is the only company that makes the friction surface replaceable by bolting it on...
I use a 3" thick concrete flywheel with a lead outer ring.  Only takes maybe 7-8 mins to get above 4500rpm but once I get that sucker spinning man oh man nothing stops me.
   Pure Portland cement, accept no substitute.
clutchmasters also makes a flywheel with replaceable friction surfaces...
				crazycanadian
It's been a while but the last clutch masters one I saw had the friction surface riveted in place.. have they changed their design?SuperK wrote:clutchmasters also makes a flywheel with replaceable friction surfaces...
http://www.rr-racing.com/clutch.htm
Clutchmasters Billet Aluminum flywheel v6
$330 + $25 shipping (msrp $439)
Replacement Friction Surface
(NOT needed with new flywheel purchase)
$60 + $8 shipping
You can't shave off much off the factory flywheel, getting it down to 12-13lbs has it's at the point where it'll risk cracking, historically speaking anyway.mitmaks wrote:You could shave your stock one and save quite a bit of weight that way.
- Josh
^^ Very True. Guys used to shave them a lot back in the day and they did crack.
The Faianza is the best IMO, I have used them on 3 different vehicles and have loved and seen noticeable increases on all of them. Keep in mind you generally will lose some low end Tq but make it up in the top end HP.. On my BP build I had it balanced with the rotating assembly, and they actually shaved several grams out of the flywheel.
I have loved those crackers since I was a kid. Sorry for being a smart a--, but I had this image of turning a metal disk on a lathe and graham crackers falling to the ground. Damn autocorrect.Josh wrote:... shaved several grahams out of the flywheel.
- Josh
Lol mmm... did not even catch it.. stupid google. I swear it is the worst auto correct.davmac wrote:I have loved those crackers since I was a kid. Sorry for being a smart a--, but I had this image of turning a metal disk on a lathe and graham crackers falling to the ground. Damn autocorrect.Josh wrote:... shaved several grahams out of the flywheel.
