Strange Axle
A forum for discussions regarding the MX-3' transmission. Swap, technical, and troubleshooting info should be placed here.
Jforce
Strange Axle
Post by Jforce »
So i got these axle's from a 323F.
And there are these oil groves in there, LSD maybe?
But don't think its type r cause there short.
Modified stock?
crazycanadian
Re: Strange Axle
Post by crazycanadian »
Stock.. can't explain why but I have seen it lots...
Sleeper6
Re: Strange Axle
Post by Sleeper6 »
Yea those are the oil cooling grooves for a jdm LSD transmission, Aaron had a set here at one time.
Jforce
Re: Strange Axle
Post by Jforce »
i dunno, look a this one, much longer shaft.
WhiteFinish
Re: Strange Axle
Post by WhiteFinish »
You're comparring a mx3 with a 323.
Is the distance transmission - wheels exactly the same?
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
MrMazda92
Re: Strange Axle
Post by MrMazda92 »
Well, one of those is a driver's side, and the other a passenger :P
It's been forever since I had both pulled at the same time, but do the shafts slide in the same depth on both sides? Come to think of it, I believe the DS is a little longer, but I may be out in left field with that one.
Re: Strange Axle
Return to “Transmissions”
