Piston marking direction
- WhiteFinish
Hi Guys,
On the K series engine, there are markings on the piston. R and L
Right and Left bank.
The casting on the piston can point in 2 ways.
Either towards the timingbelt / waterpump
or towards the ignition.
The mx3 manual says " front of the engine" ... which is nicely confusing.
- MrMazda92
Re: Piston marking direction
"Front" will be the left side, or the side facing the radiator. Unless Mazda went technical, and described the belt-drive as the front, which it should always be.
- WhiteFinish
That's not possible.
Either waterpump or ignition side.
"Front" refers to the water pump side of the engine.
1993 Mazda Mx-3 GS-Sold
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition
MY WORKLOG, check it out
viewtopic.php?f=46&t=79959
- MrMazda92
WhiteFinish, the waterpump would be considered "Belt driven".
Front, back, left and right are always a bit confusing with a transverse mounted engine. Thankfully you can always depend on engineers to be consistent. So, engines parallel to the axles for front drive vehicles kept the same front, back, left, right perspective as they had for rear drive cars. It helps if you stand at the transmission end of the motor (rear), front is belts and accessories, left is bank nearest the radiator, right is nearest the firewall.
- WhiteFinish
Thanks
would it be noticeable if you put pistons in the wrong side? all the left in the right bank etc?
I mean, would it run poorly?
1995 Eunos 30x KLZE
- WhiteFinish
Your pistons and rods are weighted for a certain place on the crank. If you change it there will be a unbalance (not that good).
RobMinhas
This is a much bigger problem with v6s then other engines due to the vibration.WhiteFinish wrote:Your pistons and rods are weighted for a certain place on the crank. If you change it there will be a unbalance (not that good).
About the piston location, it was explained to me that left and right are considered as if you are sitting on the transmission. Meaning HOnda, with their goofy wrong sided trans, will have a different left side of the engine then say a B6 or K8, even though they are transverse mounted fun wheel drive cars.
- Josh
This is quite common, and when referring to "front" always means the pulley side.
