Hey mxer's,
it's a 94 with the ZE. the disty im using is ending in the # 7172
so my car was taking a long time before starting so i took the disty apart to check the ring tone, and picks-ups etc. i cleaned it all up and re-installed it. The car starts right off the hop now no long turning, however now i have a misfire. ive taken it apart ample of times and tried to look to see if i have missed anything but everything seems fine sence the car starts right up. but i cant figure out why its misfiring now. but wasnt before.
any help would be great. also if anyone has a disty for sale in the Trenton, Belleville, Picton area i would be interested.
disty problem
- mazdaspeed23
disty problem
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
![Image](http://i1187.photobucket.com/albums/z397/moneyshot23/rsz_1994155_10152926217650640_511810948_n_zps966fe00a.jpg)
My MX-3 is nothing without me, and i am nothing without my MX-3
2007 Ford Fusion SE
- mx3_ryder
Re: disty problem
Make sure your firing order is correct and connections are good.
Plug wires bad maybe ?
Do you have another set to try ?
Try pulling each plug wire when engine is running to see if each is firing.
If its spark related this will tell ya what cylinder is misfiring or not sparking.
- mazdaspeed23
Re: disty problem
hey thanks for the reply. I figured it out. I took the disty apart right to the bottom where the pick-ups are, there was some kind of rubber melted on the megnetic pick-ups under the tune ring, so i cleaned it all up. and now shes working good again!
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
- Daveb
Re: disty problem
I have a stack of K8 Distributors in my garage
when you have one, you learn to NEVER EVER leave the ignition
on WITHOUT starting the car.
doesnt take long & your fried, sometimes the car will start bad & still run
even when its fried.
You can allso get wierd codes on the OBD I system, making you do lots of
wrong stuff LMAO
I learned the hard way
wrong stuff LMAO
1994 GS 5 speed 1.8, fresh black paint, flowmaster muffler & Little smelly pine tree
1993 RS 5 speed SOHC with 89,000 original KMs! (rising fast though).
1994 RS 4 cyl auto- running parts car with 104,000 KMs
- mazdaspeed23
Re: disty problem
what are you asking for a disty? for the 94 ze correct?
Own
2007 Ford Fusion SE
2007 Ford Fusion SE
