WTB OEM V6 exhaust manifold heat shields
Looking for an Item you'd like to buy? Post here.
This section is NOT for selling.
mx3_ryder
Post by mx3_ryder »
looking for a good set of exhaust manifold heat shields from 1.8L V6
MrMazda92
Re: WTB OEM V6 exhaust manifold heat shields
Post by MrMazda92 »
Do you need the full set?
mx3_ryder
Post by mx3_ryder »
I need the rear one, but if your front one is in better shape then mine I will take both.
MrMazda92
Post by MrMazda92 »
I have the full set, it'll be coming off later today hopefully... I'm installing headers, so I won't be needing the stock stuff anymore.
I'll take pictures tonight or tomorrow for you!
mx3_ryder
Post by mx3_ryder »
The bolts that hold those shields on (8 or 10 mm ?) strip easily. I had to tear my shields off to get to the manifold bolts. Do you already have headers? Mine are coming off. Is your y-pipe in good condition? Thanks, Chris
8)
MrMazda92
Post by MrMazda92 »
That they do, I spray the hell out of them with penetrant and tape them out with a wrench usually.
Are they short or long tube headers? I already have a set, but a friend of mine is on the hunt for some as well. He may be interested, depending on condition and price!
mx3_ryder
Post by mx3_ryder »
Short tube headers. They are in good condition with about 4000 miles on them. Finish is a little discolored from heat and egr is capped off with threaded plug. Do you have a stock y-pipe you will be removing when you install your headers cause maybe we could just make a trade or something and you can sell them to your buddy.
MrMazda92
Post by MrMazda92 »
Awesome, that'd be perfect for him!
I have a couple of them, one of them is in far better condition than the other though. I have 2 of my cars torn partially down in the driveway right now, I'll start removing it this week...
mx3_ryder
Post by mx3_ryder »
I will also take the exhaust manifolds in the trade. So your stock exhaust manifolds, heat shields and the better of the two y-pipes for my headers and y-pipe. Let me know when your close to having everything off so I can start taking mine off. Shouldn't take me more than an hour or so to get them off.
:D
MrMazda92
Post by MrMazda92 »
I have the full set currently pulled from my '92.
The y-pipe is a little dented, due to the car being so low to the ground, but it's all intact and not rusted through. :D
mx3_ryder
Post by mx3_ryder »
Send me some pics please :D
mx3_ryder
Post by mx3_ryder »
If the 92 doesn't have the better of the two y pipes i'm not interested especially if its dented. Looking for one with no damage, dents and heat shields still intact etc. I have a y pipe that's just missing a heat shield but still very usable. I would still like the manifold heat shields if you can get me some pics of those. Thanks :D
MrMazda92
Post by MrMazda92 »
I'll get pictures of the whole setup :)
mx3_ryder
Post by mx3_ryder »
bump... still looking for these :D
mx3_ryder
Post by mx3_ryder »
Just need the front exhaust manifold heat shield. Anyone...
Return to “MX-3 Related Want to Buy Forum”
