rear left wheel scrapping on something??
WestcoastSpeeder
K so this was happeing ever since i got the car. the rear left wheel scrapes or makes a scraping noise every time i make a right turn. I already removed the fuel pipe guard piece that protects the pipes and sprayed it with that spray on rubber stuff to protect from rocks. Anyone else has this problem or is it normal?
- MrMazda92
Re: rear left wheel scrapping on something??
There's no reason it should do anything like that... Do you mean during hard cornering, when the rear suspension turns? Could be a worn bushing, perhaps, if that is when you have the problem...
WestcoastSpeeder
yea its basically during hard turns which is like almost every turn i make
you think it dosnt have to do anything with alignment. Cause the guy i bought it from lived on farm lands with potholes and bumps.
Worn bushings or a bad wheel bearing. Check your caliper bolts and make sure they are tight.....WestcoastSpeeder wrote:yea its basically during hard turns which is like almost every turn i makeyou think it dosnt have to do anything with alignment. Cause the guy i bought it from lived on farm lands with potholes and bumps.
1993 Mazda Mx-3 GS-Sold
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition
MY WORKLOG, check it out
viewtopic.php?f=46&t=79959
I'd say wheel bearing. the caliper is connected to the spindle so when the bearing allows the wheel and rotor to move, the rotor will scrape on the caliper.
WestcoastSpeeder
that guys, imma try to check it out tomorrow! il let ya know if u right
Join NASCAR problem solved.
