MX3 dohc question
MX3 dohc question
I have a dohc 4 cyl mx3 now and i need a new mid shaft and im having trouble finding another dohc mx3 to get one from i was wondering if anyone know if there is another car i could get one off of.I had a kl mx3 for years this my first experience with the 4 cyl
Re: MX3 dohc question
Depends on what area of the world you're from.
The 4cyl DOHC engines used were called the B6D
http://en.wikipedia.org/wiki/Mazda_B_engine#B6D
They were only used in a handful of cars.
Mid-shaft? Are you talking about the crankshaft? If that failed, there is most likely larger problems with the engine and a swap might be in order. Search the worklogs and the FAQ, they would have information on what is needed.
Wings on an MX3? What are you thinking?
92 RS BP05
93 GS KLZE
(Previously owned by 2Fazed and then mrMazda92)
92 RS BP05
93 GS KLZE
Thanks for the answer but i was refering to the intermidate shaft that is bolted to the back of the block to make the driver side axle the same length as the passenger..
seeing that link maybe i could use one from a mercury? i was more wondering if i could use one from a protege or 626 4 cylinder or maybe a ford escort?
Ah, then this should have been a transmission question.
Do you have the G or F series transmission, auto or manual?
As far as I know the G series tranny had the halfshaft on them, and of course you'd need the B series bolts to line up.
I've torn down a Ford Escort GT (91-96) and a Mercury Tracer LTS (91-96) which both had G series transmissions and the halfshaft. They were mated to the BP 1.8 DOHC engine, but the shaft should line up. Take your broken shaft to the junkyard and compare it to the shaft on these cars.
Oh and check the Mazda protege LX ...
92 RS BP05
93 GS KLZE
92 RS BP05
93 GS KLZE
- Tavman_1213
Escort GTs have both F and G series and some of the F series do have the half shaft!!! I have learned this from personal experience!! Be really careful which one you get they look exactly the same but the G series is about 3/8'' longer!!Demonic1 wrote:As far as I know the G series tranny had the halfshaft on them, and of course you'd need the B series bolts to line up.
93 White RS- BPT Built not bought!!
Worklog: viewtopic.php?f=46&t=78988
- Ryan
You may be interested to know that the bearing in the midshaft is a serviceable part, so unless you ruined splines, there may be no need to source an entirely new shaft.
http://www.mx-3.com/manuals/showimg.php ... /M-022.gif
Thanks man But I do know that I did it to my v6 a couple times however it is the splines that are messed up..
