Diagnostic box questions and running issues.
crazycanadian
Re: Diagnostic box questions and running issues.
Post by crazycanadian »
cWs306 wrote:yah, no theres no light what so ever.
Take a test light and find the wire that commands it on coming out of the pcm... Back probe the wire and clip the test light to it and run the test light to ground... Now you can test that your PCM can still turn on the engine light and also check codes with out pulling the gauge cluster apart...
