Klze lack of powe(hp)
Re: Klze lack of powe(hp)
gotcha man . hmm hows your spark ? is it very powerful or orange dull
also you could try this simple idea -- got it from other board memebers --
( open the Vris butterfly and close it on a piece of paper ) do this to both vris # 1 and # 2 go for a good run in 2nd gear that will allow the vris to open and if the paper is GONE the vris are working simple test
also another test it to start the car warm it up " no damage to engine " open hood then blurp the throttle via throttle body and watch the vris either open or not open from 1000 - 6000 they should have both opened up and closed when you let off the gas
also for your low qr mile times .. how does the car pull on the street through the gears does it feel sluggish ? does it feel rough running ?
and for no engine lights on - > at one time my bulb was burnt out and i just happened to scan it and i had 2 codes cyl 5 misfire P0305 and a EGR code becuase mine is not connected did you check the codes with a scanner OBDII
or paper clip in the DAIG box under the hood if OBDI and watch the check engine light flash and corrisponding flashes means what engine code it is .
hope i can be some help
Red96'Mx3 KL-ZE 2.5, CAI, full 2.5'' exhaust,cat delete, black stock rims polished lip, cross drilled brakes, (aftermarket bumper with halo foglights-Needs work) .
http://www.cardomain.com/id/whitete
Previous rides
Purple94' Mx3 K8-ZE CAI, Exhaust, plugs,wires
Purple95' Mx3 K8 american, CAI, Exhaust, plugs, wires,cap/rotor fuel pump, short shift,
Black 94' Mx3 i4 Stock ( hit by dear )
Previous rides
VRIS are working perfectly now, i went to test it to the drag tonight, turns out when i arrived there it started raining so i guess ill be testing next week
Both VRIS not opening would have to cause a large decrease in power. It would be far worse than having a K8 manifold on the ZE.
Interested to see your 1/4 mile now.
1995 Eunos 30x KLZE
thursday for sure...was raining last week so it got canceled eh.
update to my issue!
15.7 on qt mile and 88mph
still not as good as i think it should be,
changed the cluster to its original one and noticed that on both cluster i have NO CEL lights even on start....could it be normal?
does anyone have any other ideas?
i was told i might be running leannn.how do i check that?
anyways, im alll ears.
thanks!
thanks!
- Josh
15.7 is not horrible, should be closer to high 14's. What kind of wheels tires are you running? still could be your launch and shift points. you should try and take video next time
mags on 205 55 15 brand new falkens
- Josh
wheels are not the issue then, what flywheel are you running? the ZE flywheel or the K8 flywheel. And what is the altitude that you are at above sea level?
okay this is getting kinda weird lol. k8 flywheel and 82m xD what the eck does the sea level have to do with my speed xD
Sealevel affects power as the air gets thinner as you get higher
Montreal is about 50m above sea level
